Reload this Page >
Smoke with vectored thrust
Old 04-06-2013, 01:19 AM
Ray Wasson
Default Smoke with vectored thrust
Is anyone using smoke with 2 axes vectored thrust?. I have a CARF Rookie Last Edition with dual axes vectored thrust and there is not enough room to inject oil at the tailpipe when nozzle is at full travel. I think it may be possible to put a nozzle in the cone and connect with flexible tubing.
Would appreciate any pictures or suggestions.
Ray
Old 04-06-2013, 04:39 AM
Ravivos
Ravivos's Avatar
Default RE: Smoke with vectored thrust
why not inject the smoke fluid at the output of the turbine?
on my rookie, i can attach the smoke fluid injector directly at the exhaust cone of the turbine and the vectored pipe doesn't need to be changed.
Old 04-06-2013, 06:58 AM
BaldEagel
BaldEagel's Avatar
Just be careful with the full vector that the movable part does not contact the injector and rub a hole in it, the oil will get everywhere if it does.
Mike
