Jeti DS-16 High end transmitter is in!
#76
The JETI protocol don't specify anything about voice files, it just specify value and unit. Percentage is correctly displayed on the TX screen, so I think that the issue is not on telemetry side, it is on voice assignment. I will check next week, have the radio at workshop.
Gaspar
Gaspar
#79
Late response, but...The number of available "channels" within the 2.4 GHz band is directly dependent of the amount of bandwidth the transmitter uses. Some systems could easily have 80 different channels to utilize if they do not use a lot of bandwidth. This band does not have defined channels like the 72 MHz band has.
Steve
Steve
Thanks for the quick response. Your answer though, conflicts with information not only from Futaba but, from a number of other manufacturers. I'm not saying you're wrong, just that I am confused because of the conflicting information.
I do know that with some systems (Weatronic for example) you have the option to reduce the # of channels that the system hops across in order to meet regional standards ( France for example has a smaller portion of the band available)
Mike
Mike
#80
Hi,
Soon after i bought the DS16, the back light started to give trouble, and finally stopped working
Jeti sent me a replacement,
after 2 days the replacement also went dead
Anyone have similar problems
