Reload this Page >
DerJet Hunter here!
DerJet Hunter here!
Old 05-11-2013, 09:03 AM
Geoff White
Geoff White's Avatar
Default RE: DerJet Hunter here!
What an excellent example of a manufacturer taking note of feedback and acting upon it.
Big thumbs up for Derjet.
Old 05-11-2013, 10:43 AM
Dave Wilshere
Big G
Yes, amazing company. Each time we discus improvements they respond immediately, since my kit a few things have been changed, its more important to them that things are as good as possible, rather than pumping out kits.
D
Old 05-11-2013, 11:57 AM
bobg
Geoff /Dave ...now that would inspire me to buy a Derjet model,,a company who listen ! And aren't afraid to discuss issues no matter how small !
Old 09-20-2013, 02:51 PM
marquisvns
marquisvns's Avatar
Any recommended CG location? Thanks in advance gentlemen,
Barry
Old 09-21-2013, 07:46 AM
derjet
Barry, Sorry to send the construction manual so late. The manual comes into the final soon. You may start at 29 cm of the CG point.
Regards, Jack, DerJet Model
Name:	CG of Hunter.GIF
Old 09-23-2013, 01:13 PM
  #31
marquisvns
marquisvns's Avatar
No problem, thanks for the info Jack!
Regards,
Barry
Old 10-07-2013, 03:33 PM
  #32
Gonzalo38
Gonzalo38's Avatar
Any news on this plane ? Need to buy a plane of this size and I love the Hunter...... but also the Vampire. Derjet has both models but trying to make a decision on which way to go.
Old 10-07-2013, 05:39 PM
  #33
marquisvns
marquisvns's Avatar
Here are some pictures taken by Ken Simmons at Sepulveda basin. Kim McNulty did a great job putting it together, including his first attempt of weathering. We maidened it at 28cm from trailing edge but was grossly tail heavy, ended up 5 more oz of lead up in the nose. A total of 3 flights on the first day, also to note, the gears didn't want to come up until you roll it inverted and give it negative G, when they did, somehow didn't want to come down, so had a gear up landing on the last flight, some damage, but will fly again, hopefully sooner than later...
I must add, once the gears retracted, it was just a pure joy to fly
Cheers,
Barry
Old 02-25-2014, 05:54 AM
  #34
Dave Wilshere
New scheme just added...
ID:	1972204   Click image for larger version
Old 02-26-2014, 10:00 PM
  #35
quist
My Feedback: (198)
quist's Avatar
I put the first two flights on the Hunter today. I had a very hard time getting the jet to rotate. The nose sits very low. Like Barry, I was unable to get the mains to retract in the air. The nose gear and door worked fine. The Hunter landings were very nice. It had very good power with the 120sx.
Old 02-26-2014, 11:43 PM
  #36
Dave Wilshere
On the ground what psi do you need to retract the main gear? My guess is that you must have had some good ground speed if you were struggling with rotation (how much flap were you using?) Were you climbing when you first hit the retract switch? The big heavy wheels and draggy gear doors mean there is the weight/G increase to the cylinders if you were climbing and aerodynamic drag if it was travelling fast.
On my Vampire I rotate, check the climb go level a second or two-while hitting the gear switch and the gear always goes.
Looks great in that scheme!
Dave
Old 02-27-2014, 12:03 AM
  #37
David Gladwin
David Gladwin's Avatar
Nice, but a shame they got the wing leading edge so wrong!
The leading edge extension was fitted to the F 6 wing to prevent pitch up near the stall. The le extension projects well forward (about 4 inches) of the original le RIGHT to the tip, it does NOT taper to the original le.as on this model.
Mick Reeves got this right, the forthcoming Tomahawk Hunter has it right, DJ and Airworld, wrong.
Doing it it right would improve scale accuracy and improve handling near the stall, reducing the possibility of tip stall when pulling G.
Take a look at the real Hunter, F 6 onwards, although the Danes modified their F4s to improve handling and when RAF F4s were converted to T7s the le extensions were also added.
David.
Old 02-27-2014, 01:45 AM
  #38
Dave Wilshere
Old 02-27-2014, 01:47 AM
  #39
Dave Wilshere
Seeing Reto designed the DJ model from the HT/Tomakawk cad files, I'd expect it to be right. my DJ wing is the same as this one.
Old 02-27-2014, 02:58 AM
  #40
Jgwright
http://www.flickr.com/photos/photonu...n/photostream/
It looks from the full-size that David G is right here. I have looked at photos of a few full size planes that have been caught almost plan view. A straight edge on the outer wing leading edge shows it to be parallel. The 3 View must be wrongly drawn! There is a Hunter at Flixton, my local air museum, I might pop in and check it.
John
Old 02-27-2014, 03:18 AM
  #41
Dave Wilshere
I'm now told most of the 3 views are wrong...
Even squinting I can tell its a Hunter, so not flying it in competition, I'm not fussed!
Dave
Old 02-27-2014, 04:44 AM
  #42
David Gladwin
I knew my post would be controversial because most of the Hunter drawings are wrong on this point. Most, but not all, of publications I have seen, seem to copy the mistake.
However the LE extension play an important aerodynamic function as they change the mean camber liner at the outboard wing section, increasing the max CL and reducing the angle of incidence (the chord line of the extension is angled downwards, to prevent tip stalling which results in pitch up due to forward movement of the C of P, on a swept wing such as the Hunter. The Phantom and HP Victor also have, had, extended drooped outboard LEs. and there are probably many others too.
My point is that the Hunter models from DJ and AirWorld, by getting the leading edge wrong, are degrading the model's aerodynamics. Doing it correctly would reduce the chance of tip stall, making the machine safer to fly and, of course, more accurate, scale wise. !
I know the Reynolds numbers of the model are totally different to the fullsize machine but every little helps.
But don't take my word for it, go and look at a real Hunter !! I will await John's Flixton visit report !
David.
Old 02-27-2014, 06:41 AM
  #43
JackL
My Feedback: (7)
JackL's Avatar
Here are a couple of pics of an FGA-9 in the Singapore Air Force Museum
ID:	1973025   Click image for larger version
Old 02-27-2014, 07:08 AM
  #44
Dave Wilshere
David
Obviously you are correct on the scale outline, flying wise I've flown a lot of Hunters and all are easy going and not at all tip-stally. The fact the MR Hunter is one of the scale ones proves the point, as the two or three I have flown were the worst handling Hunters I have flown!
Its a pity molded aeroplanes are often done wrong, most of AW's models are wrong in one way or another, but they all look and fly great as models, so I guess it depends what is important to you.
Dw
Old 02-27-2014, 08:09 AM
  #45
Jgwright
I have been to the museum and taken some photos which are exactly as expected. The photos are the same as Jack has posted except the Singapore Hunter is nice and clean and free of algae! I took a photo at the junction of the extension on the inside. There is no droop down just a smooth shallow curve from the underneath upwards to the leading edge.
This is a list of the planes in the museum, nice to have it close.
http://www.aviationmuseumguide.co.uk/museum_flixton.php
John
Name:	DSC_1627 small.jpg
ID:	1973040   Click image for larger version
Name:	DSC_1626 small.jpg
ID:	1973041   Click image for larger version
Name:	DSC_1626 small horiz.jpg
ID:	1973042   Click image for larger version
Old 02-27-2014, 08:29 AM
  #46
JackL
My Feedback: (7)
JackL's Avatar
Dave Wilshire, since you had both the Ripmax and the Der Jet Hunters, how did the Ripmax L.E. extension look? I would assume since it is basically the Mick Reeves Hunter that the Ripmax would be correct....
Old 02-27-2014, 09:02 AM
  #47
Dave Wilshere
No Ripmax ones are like the DJ and taper to the tip. Although its based on the MR model, the Ripmax model is very different right from undercarriage positioning to incidences, the Ripmax versions I have flown (4) all fly better than the MR examples.
I expect my DJ model to fly well too.
Dave
DJ on a Ripmax wing
Old 02-27-2014, 10:15 AM
  #48
k_sonn
My Feedback: (32)
k_sonn's Avatar
Hi Tony. I had a similar issue with the Ripmax Flying Ledgends Hunter. It would take longer in the air for the mains to retract than it did on the ground and the main gear doors would close before the gear could fully retract. I wasn't using restrictors. I went from 100 psi to 120 psi but that didn't solve the issue. I added another tank to add volume but that still didn't work. I was using a UP3 valve so I changed it out for the Jetronics valves and still had the issue. I ended up solving the problem by putting my finger on the gear switch during the takeoff run and as soon as the Hunter rotates, I flip the switch, count to 3 and then start the climb out turn.
Kirk
Old 02-28-2014, 06:02 AM
  #49
AVIOJET
AVIOJET's Avatar
Hi all, very interesting theme.
Some months ago I purchased from MR plans, canopy and a set of wing airfoils. I am working on my own CAD plans and the extensión L.E. taper 1°20'34", i.e. is not paralel with the L.E. of the central wing.
BTW is very dificult to get with accuracy the anhedral form the plans, I guess is 3° total anhedral but I'm not sure, any one can help me?
I attach some pics of my electrical nose gear.
B.R.
Jesús A. Serrano
ID:	1973425   Click image for larger version
ID:	1973426   Click image for larger version
ID:	1973427   Click image for larger version
ID:	1973428   Click image for larger version
ID:	1973429   Click image for larger version
Old 02-28-2014, 01:03 PM
  #50
David Gladwin
The anhedral angle on the fullsize drawings I have is 2 degrees.
No, the LE extension will not have a LE parallel to the inboard mainplane section. The chord of the extension at the inboard point is just on 6 inches (measured at right angles to the wing LE) and at the tip the chord is just about 4 inches, so the 1 degree difference you noted is about right ! They are just under 10 feet long so they create, in total, an extra 9 sq. ft of wing area and move the normal C of P forward.
For the most part the extension will have NO effect on handling although it will improve the Max CL BUT at the stall (both 1 g and accelerated) it should make things more docile. Remember, in military fighters and trainers the aircraft is often flown very near the stall, i.e in a max performance turn pulling lots of G, is often nibbling at the pre-stall buffet, the point at which the maximum rate of turn is achieved.
Sometimes these small aerodynamic features can have a considerable benefit. The BVM T33 was a dog at the stall, spinning at the drop of a hat. This was caused by the drooped LE at the root, creating undercamber. Fill in the undercamber and it flew much better at low speeds and the instant spin tendencies disappeared.
David.
