Reload this Page >
Turbine waiver?
Turbine waiver?
Old 05-02-2013, 12:07 AM
  #51
jp1961
Default RE: Turbine waiver?
I'd like to thank James Smith and the other members of the Flying Pilgrams for your help. I'll contact you shortly to set something up. Thanks again.
Jeff
Old 05-02-2013, 03:52 AM
  #52
Art ARRO
jp1961 and All,
I'm glad that you were able to connect with a turbine CD to take your qualification flight. I recommend that you review the flight requirements beforehand, as described in the AMATurbine Safety Regs. You may be asked on startup procedures, ECU fail safe, fire suppression and turbine lag management., etc. Also, download and print a copy of the Turbine Waiver Application from the AMA website for completion and submission afteryour qual flight. Good luck and you'll soon join the ranks of waivered jet pilots. Fly safe and happy landings.
Art ARRO
Old 05-02-2013, 07:13 AM
  #53
zacharyR
just give him the waver . he can crash millions of jets and it wouldnt make Detroit any less crappy then it already is !
Old 05-02-2013, 07:58 AM
  #54
[email protected]
you can have trouble with any type airplane there was a freeflight next to our field when he landed the fuse wAS still lit caught the field on fire burned 2 blocks of dry grass
