Operation of Brakes on Tx
My Feedback: (40)
RE: Operation of Brakes on Tx
ORIGINAL: redtail
Hi Guys, could someone draft up the programming mix for a JR 12X to use both the right slider for parking and down elevator for braking when the gear is down? I am truly a jet rookie who will be building my first jet (JetMach 60 with the KingTech 60G) this fall. Just like the Install Thread here on RCU, these are wonderful teaching lessons the more experienced guys are letting us rookies see. Many thanks for that. Chic
With your 12X, go to Device SEL in the System Mode List. Scroll to the AUX channel you are using for brakes and select/highlight it (I normally use AUX 7). Scroll through the switch options until you highlight one of the slider switches. Most guys use the right slider which is designated "FLAP LV". Make sure the channel is "ACT" and if not, highlight and select until ACT appears.
In the Travel Adjust menu, select values that will have the brakes OFF with the slider up and full brakes with the slider all the way down. The direction and throw will vary depending on the type of brake setup you have, servo arm length etc.. With a UP-6 valve, 9411 servo and normal direction of travel, my values are +104% and -82% on my Futura.
Get rid of (inhibit/clear) any mixes you currently have to the brakes. Select a Standard Program Mix (51, 52 or 53), activate and enter ELEV (master) to the AUX (slave) channel you have brakes on (in my example, AUX 7). Enter values in the Pos.0 fields to get braking action with down elevator. On my mix program in Pos.0 I have D-125%/U 0% and all 0% in POS.1 Scroll over to the "Gear" box and select "1". That will inhibit the mix with the gear switch up.
That should do it. I have to bump in a few clicks of down slider to get the brakes to come on with the first movement of down elevator. As I mentioned earlier, with the "parking brake" ON (slider down), pushing down elevator will try to drive the brake servo further, so don't do it. Use one or the other if you are holding short for takeoff, for example.
Let me know if you need clarification on any of this.
Craig
Hi Guys
Thanks for all the info, it would appear that opinion is fairly evenly divided,I will give the down elevator option a try to see if I like it.
Thanks and Regards
Peter
Thanks and Regards
Peter
My Feedback: (25)
ORIGINAL: RAPPTOR
HOW MIX TO TRAINER BUTTON?
then also program my right slider as trim so I can use the slider if I want or can also use it as a parking brake. Again this is on my Futaba 12FG
#31
My Feedback: (54)
ORIGINAL: FenderBean
I keep mine on a slider on the right side, this prevents interfering with the steering side of the remote during the braking period.
