Help me ..airpower multi funtion valve .
Hello Help , I purchased a evo/st multi function valve with a jet from skymaster . 1st time I have used it I have no control over retracts . My brake works perfect and when using it in manual mode It works correctly . The top air gauge works correctly the one under it reads 0 pressure even when my air filler gauge reads 90 psi . I have connected a servo to the lead that goes to the multi valve and the servo works in a full sweep . I have tried the radio set in 100 and 150 percent and it does work . I am using futaba 18mz with sbus twin recivers and powerbox competition . What is wrong ? Please help me ....
RE: Help me ..airpower multi funtion valve .
Please share the answer. My top air gauge (brakes) shows correctly but the lower (Gear) shows 260psi constantly even though a separate air gauge and filler gauge shows 75 psi. The valve operates fine, even the failsafe set at 50psi works even with the faulty readout. I live with the readout error, but interested to know if there is something I can do to fix it without sending it away.
When my gauge reads 0 psi the retracts dont work as the gauge is faulty . Yours works as the presure is higher than the min setting to work . Yours operates as it is not a low reading , but your would not be good in failsafe gear down was needed .
My gauge is going back to dealer for repair .
