Tamjets Failsafe Question
My Feedback: (15)
I have set this up before but forgot something and my instruction sheet doesnt clarify something...
As I remember the third set of pins can drive an aux channel just as the gear channel....is that right?
I have a separate gear valve and want to make sure that both door and gear will go down if necessary.
Dave
Dave
RE: Tamjets Failsafe Question
ORIGINAL: tamjets
Left the Aux alone. Just follow the instruction how set up and program.
Tam, that's $20 for 3 minutes of translation (my rates have gone up)
Or you can give me a discount on my next pipe. I ended up connecting an ESC to one of your old smoke pumps that I had by the way. Works great too!
Shaz
Hi Tam
I have an old tJ failsafe device that unlike newer version, does not retract when air is pumped above the set point pressure. Yes, with radio on
Is there a way to upgrade this?
Regards
Nuno
Regards
Nuno
ORIGINAL: jetnuno
Hi Tam
Regards
Nuno
Hi Tam
Regards
Nuno
Send to my shop.
