Reload this Page >
FEJ A-10 1:6,5 scale
Old 05-20-2013, 09:55 AM
cmjets
cmjets's Avatar
Default FEJ A-10 1:6,5 scale
Hello friends:
I have the chance of get an A-10 of FEJ in 1:6,5 scale and I am looking info of this model in this size, because there are much more in 1:6,25 and my question is if is identical model or has diferences with the big brother ?
Has the speed brakes in the ailerons like the 1:6,25 ? or not has this function ?
Someone can show me photos of the A-10 in 1:6,5 scale ? Thank you very much in advance.
BR from Spain.
Carlos Márquez
____________________________________________
www.cmjets.blogspot.com
Old 05-20-2013, 10:00 AM
dubd
dubd's Avatar
Default RE: FEJ A-10 1:6,5 scale
I know of two people who had these planes. One sold it because of poor build quality. The other is stuck with it because he doesn't want to pass on the POS to another modeler.
Old 05-20-2013, 11:17 PM
Damo260
Damo260's Avatar
This is my FEJ A-10 1/6.25 I'm very happy with the build quality and the finish of it. I'm going to run to Kingtech 140G I haven't flown my yet due to work and family things plus buying other planes plus I'm finishing off my F-16. My mates has got the 1/6.5
Damo
ID:	1883915   Click image for larger version
Old 05-21-2013, 03:07 AM
jetnuno
Hi
It would be nice to see a video... Have you checked your elevator? Does it have a alu or carbon tube between the 2 half stabs? The 2 planes I have seen don't have it. In top of it you'll have to put a 1Kg rudder each on the tip of the elevator and no TUBES.
What do you think of this? To my knowledge this is not a proper reinforced elevator for this type of bird. If you can please post some pics of the inside rear fuse of yours.
Regards
Nuno
Old 05-21-2013, 11:37 AM
Damo260
Damo260's Avatar
ORIGINAL: jetnuno
Hi
Regards
Nuno
Hi Nuno
I'm not turning this thread into another Witch Hunt On FEJ cmjets ask a question so I reply.
And like I said I'm very happy with the build quality and the finish of it.
Damo
ID:	1884017   Click image for larger version
Old 05-21-2013, 12:15 PM
jetnuno
ORIGINAL: Damo260
ORIGINAL: jetnuno
Hi
Regards
Nuno
Hi Nuno
Damo
Hi
That´s exactly what you're doing.... and in bold.
I am also trying to help Carlos,cause he's my friend.
If you read his post, he asked for photos. Could you reply him on that matter?
Regards
Nuno
Old 05-21-2013, 12:31 PM
Damo260
Damo260's Avatar
ORIGINAL: jetnuno
ORIGINAL: Damo260
ORIGINAL: jetnuno
Hi
Regards
Nuno
Hi Nuno
Damo
Hi
Regards
Nuno
Hi Nuno
As I did photo of mine and a photo of my mates. I'm not going to pull the plane a part just to photos of the inside.
Here is the build thread on mine plus Aussie Bart has photos of his FEJ 1/6.5 [link=http://www.rcuniverse.com/forum/m_10657203/anchors_10657203/mpage_1/key_/anchor/tm.htm#10657203]Fly Eagle Jet A-10 1/6.25 Build [/link]
[link=http://youtu.be/e8CJz-yrmEc]FEJ A-10 Maiden[/link]
Damo
Old 05-21-2013, 02:03 PM
jetnuno
Hi
Here are some pics from an A10 inside rear fuse. The first pic is from a regular lay-up with incorrect incidence original sent with the kit. The second one is HC with correct incidence later sent by FEJ.
The owner from this bird will have rear HC and front regular layup fuselage[&:]. Plus the paint does not match, so he's not that happy...
As you can notice there is no alu or carbon tube between the 2 half stabs. Remember that in the tip of each stab is attached a rudder with arround 1Kg.
In the later rear fuse there is an HC former, but behind it there's no stab tube as well.
Draw your own conclusions.
Regards
Nuno
ID:	1884041   Click image for larger version
Old 05-21-2013, 02:23 PM
Damo260
Damo260's Avatar
ORIGINAL: jetnuno
Hi
Regards
Nuno
Were are you going with this if you are not happy don't buy it then. I've had Skymaster, Feibao, CARF planes they have all the same problems at the end of the day we still buy them.
And were are you getting weight from??? my fin and rudder doesn't way 1kg with servo mine ways half kilo.
Damo
Old 05-21-2013, 02:27 PM
cmjets
cmjets's Avatar
Hi again friends:
I understand that the strongal question is really another question.
I really want to know if both models are same scale detailing, because the 1:6,5 not has airbrakes in the ailerons and I don´t know if there are another diferences betwen models.
I am looking some 1:6,25 models and I think that are best that 1:6,5, for scale and for size.
Thanks for your help and answers.
Regards from Spain.
Carlos Márquez
Old 05-21-2013, 02:34 PM
jetnuno
ORIGINAL: Damo260
ORIGINAL: jetnuno
Hi
Regards
Nuno
Damo
Hi
I won't, believe me.
The rudder weight was reported by the owner. Maybe it's not that accurate but, I don't own one, sorry. Perhaps you can enlighten us with more accurate data.
Nonetheless of the rudder weight, a spar between stabs is a must, in my perspective.
Regards
Nuno
