TEXAS JETS - MT. PLEASANT, TX
#52
TX
RE: TEXAS JETS - MT. PLEASANT, TX
hey , so to the google earth users...
can you really easily pull off measurements from google earth ?
is it in the menu some where , how to select what to measure ?
i have some some local runways that be cool to see how long they are.
thanks , Joe
thanks , Joe
#53
TX
Joe,
Pull up your image and then go to the tool bar menu on top. Click on show ruler. Then click on path. That will give you what you want to know.
Gus
Gus
#55
My Feedback: (7)
ORIGINAL: vernonms
looking forward to friends, BS, flying, BBQ and key lime cake.
Vernon
Vernon
Vernon,
As far as friends go, your on your own. Flying is a given as long as Gus has the building grounded for the lightning storm. BBQ is always good as well as the Key Lime cake. ( Don't forget the Steaks from the meat market ) BUT.... As far as BS goes, ther is no problem there a assure you !!! The will be so much BS there you will be able to take some home with you !! I hope you can fit it all in the truck !!!. Your gonna need a trailer to haul all the BS home !!!
Danno
#58
TX
ORIGINAL: erh7771
Do you know what the outlet wattage is?
I'll bring extra packs either way
ORIGINAL: gushudson
Yes, there are a lot of outlets in the pit area. That should be no problem at all.
Gus
Gus
#59
ORIGINAL: erh7771
ORIGINAL: gushudson
Gus
Gus
#61
My Feedback: (7)
ORIGINAL: AndyAndrews
115-120/60/1 most likely. Just standard outlets.
ORIGINAL: erh7771
ORIGINAL: gushudson
Gus
Gus
I don't think juice is a problem.. Gus said he just repacked the bearings in the electric meter !! Besides, the power plant is just accross the lake. You can run you a cord over there if you need to.
Dan
#66
TX
ORIGINAL: f106jax
I've always loved those Pittsburg Hot Links, worth the trip to TX by themselves! Gus, in case I add some weight from all of the hot links, do you know what the Mega Pascal strength rating of the pilot station concrete pads might be?
Just to be safe I have a concrete truck coming to add an extra layer of concrete to the pilot stations. I don't think that you will have to worry about the added weight of the Hot Links. If you don't think that will work let me know and I'll think of something else.
Gus
#70
TX
whos bringing the Jet skis? lol
#71
TX
ORIGINAL: bcovish
OK, the long range forecast said to bring a lot of sunscreen [8D]
#73
My Feedback: (7)
ORIGINAL: bcovish
Bob'o,
Your long range forecast suck !! You said the same thing for Austin. Thank god you and the tractor was there, my trailer would still be stuck there !!! You need to find a new weather station. I believe Gus though.. If he says it's gonna be nice, it's gonna be nice. I'm gonna bring you a helmet with a lightning rod on it !!
Danno
#74
My Feedback: (30)
ORIGINAL: rcjetsaok
Dan
ORIGINAL: erh7771
ORIGINAL: gushudson
Gus
Gus
Dan
#75
TX
ORIGINAL: erh7771
lol .... that'll make for a lot of flyin and a little bit of smoke ...lol
ORIGINAL: rcjetsaok
Dan
ORIGINAL: erh7771
ORIGINAL: gushudson
Gus
Gus
Dan
