Thoughts and ideas regarding gyro on ailerons
#52
I have been using the Demon Cortex since earlier this year it has 5 Input/Outputs and is super easy to setup. It learns your radio setup during the programming phase.
Example setup in a Bobcat. You can stabilize ALL flight surfaces and the nose gear and still use crow on the ailerons.
Futaba users can use the built in gyro function to set your gyro rates.
#53
I started using a gyro in my 2nd jet I ever owned. On the just the nose gear. I will NEVER have a jet that doesn't have a gyro on the nose wheel.
I've dabbled on other surfaces. And I loved those as well. I haven't become religious about putting gyros on other surfaces but they can really help.
I had gyros in a small f-14 that I had, (aileron and elevator) and it really helped tame it with the wings swept. (R.I.P little tomkitty)
I've had that same little f-86 and I almost put a gyro on the rudder. I just lived with dutch roll. It would freak me out the most on final but quickly dissipated.
#54
