Jet Central Rabbit 100 (Mint) trade for a Jet Munts VT-80?
AB, CANADA
Needing more power? I know this is truly a shot in the dark...but is anyone interested in trading over a Jetsmunt VT-80 in exchange for a pristine five flight new Jet Central Rabbit 100? I just don't need 23 pounds of thrust in a 17 pound jet. The VT-80 would be a much better fit for my tiny aircraft. The Rabbit literally has five flights on it. If I can't find a trade then I will list it in the classified but that won't happen till later. If I do list it it will be for 2k so let me know if you are interested.
Email me at [email protected] or PM me here. Thanks guys!
RE: Jet Central Rabbit 100 (Mint) trade for a Jet Munts VT-80?
I would say keep the rabbit you can always throttle back and in the future if you need more power you will have it. Also wont you be
taking about a $600.00 loss?
My Feedback: (48)
That doesn't make much sense. Both engines weigh about the same so there's no advantage to making the swap versus dialing down the Rabbit. Just look at the power curve and limit the max rpm to give you 17 -18 pounds thrust. You can always increase the thrust later if you want for this or another application.
Joe
Joe
AB, CANADA
It's not just the power but also the fuel economy. The tanks in this bird are not very big. Looks like I've got something sorted guys. Thanks.
AB, CANADA
Yes but overall the VT80 according to tests is more effecient than the Rabbit is it not? Which works better for my small gas tanks.
VT80 at max thrust is 258cc per minute
Rabbit at max thrust is 389cc per minute
Now I realize those numbers are at full throttle at thier rated thrusts. So if I dial the Rabbit back to 18 pounds, I wonder how I tell what the cc rate would be and what it would compare to the VT-80. The P-60SE for example has a higher CC rate per minute yet only puts out 12 pounds of thrust.
My main goal is 17-18 pounds of thrust and as little fuel consumed as possible. Are you guys saying that if I dial back the Rabbit, that the difference between the VT-80 and the Rabbit in terms of fuel consumption just isn't all that much? Please fill me in.
AB, CANADA
I get that. But please answer one thing for me. If a turbine has less consumption at full throttle compared to another brand...does that also mean that it would have less consumption say at idle? It's not all about being in the air. Yes taxi tanks can help but I'm thinking if I'm flying around etc and doing basic loops rolls or even just coasting along, that a turbine that uses less fuel right off the hop would also give me longer flight time overall.
The question is...is the VT-80 better on gas overall than the Rabbit 100. Regardless if the 100 is dialed down. Hopefully someone can answer this...
My Feedback: (10)
FL
Pound for pound of thrust, the are very close. By reducing the max RPM in the run menue to the rpm/desired thrust (look at supplied chart) the turbine (Rabbit 100) will run cooler and use less fuel. The Rabbit 100 is one of the most efficient turbines in it's class. RCJI did a glowing report in one of the past issues. BUT. . . .one questions prevails over all others; Why give up the Lifetime Warranty ? ? ?
As others have said, reduce the thrust and enjoy the turbine.
Regards,
Eric
Regards,
Eric
My Feedback: (134)
Maybe this will help. I have the Tams 1/8 scale F16 with a Rabbit that was converted to Kero start. Not sure if that makes any more power or not but lets just say it is 19 lbs of thrust. I don't have it dialed down but almost never need full throttle and when I do it is just for take off and maybe a climb or two. On a 6 minute flight I might burn through the two saddle tanks but that is it. On my last flight I landed at about 7 minutes and turned the turbine off at 9 minutes and still had over half of the center tank left. The Rabbit is very efficient. I'm not sure you could do any better with the 80.
Most current turbines are made to be there most efficient at the upper scale of there rpm , just dialing down the rpm will not decrease the fuel consumption as dramatically as most think yes it decreases fuel consumption but not as much as most would think. Glenn keep the 100 and buy a vt80 for the 16 you will find a home for the 100.
Kevin
Kevin
Keep it, dial down the output and then measure the consumption by measuring a specified amount of fuel and whack the engine on your desired output of around 19lbs.
Basically set up a 2L cola bottle as your main tank, mark a black line on the bottle at the moment you whack it to your full throttle that you desire and measure for one minute. Mark it off at the moment you back off back to idle. Then do the math by using a measure cup to determine what the fuel consumption is.
This is clearly one of those situations where in a year's time you may think 'Why the heck did I sell the Rabbit?'
More fuel, right on the CG, looks cool.
I think BVM makes one. - John.
AB, CANADA
You know I never considered a centerline tank and it does look cool!!
My Feedback: (57)
ORIGINAL: Pepperpete
However, do keep in mind that in the TAMs F-16 you can fit an aditional two 8-10 oz tanks above the inlet behind the cockpit. This is where I installed my smoke tanks. It takes the extra fuel weight very well.
David
My Feedback: (57)
ORIGINAL: kev-o
Kevin
Kevin
I always thought they were the least efficient at full throttle...
Eric? Barry?, Bob?, Gaspar?, Oli?, Anyone?
My Feedback: (48)
ORIGINAL: kev-o
Kevin
Kevin
The bottom line is that he would not be able to tell the difference in fuel comsumption between a VT80 and a Rabbit dialed down to the same maximum thrust.
Joe
My Feedback: (57)
ORIGINAL: BlueBus320
Just to give you an idea of what it looks like, this is my Tamjets 1/8 F-16 with D4S cl tank taped to the bottom. I still need to complete my install.
Jay
Jay
My Feedback: (57)
[quote]ORIGINAL: FalconWings
Jay
Jay
I fly with a lot of ex 16 guys, heard some great stories.. I'm jealous..haha Formation sounds like fun! We'll get some cool pics[8D]
