Elite Aerosports Shockwave?
#126
This is the main retract body; http://www.airtech-germany.de/epages...Products/12002 the so called "new version" The old version had slot cuts butween the 2nd and third holes
This is the nose retract body: http://www.airtech-germany.de/epages...Products/12001 the nose was the same no difference in versions
These are the Main struts: http://www.airtech-germany.de/epages.../Products/2106
This is the OIL Dampener that was included in the original main struts (BUT IS NO LONGER INCLUDED): http://www.airtech-germany.de/epages...oducts/D002264
Here are the wheels and brakes: http://www.airtech-germany.de/epages.../Gummi__Rubber
All made and designed by Erwin for Air-tech for sale to ANYONE and has been FOR MANY years, even in 2011.
IF the plane was offered without gear, then your best bet by far is to buy this: http://www.airtech-germany.de/epages...ucts/1001-10-e 100% guarenteed to work on the shockwave and is drop fit.
All made by ERWIN from Airtech using components he has been designing and selling.
believe what you will, i'm sure your Ego is too big to accept this and you will keep saying it was specially built for the shockwave
#127
Sorry,but i would like to ask three more questions 1 Are these kits painted in the molds and if so are their any seams?
2 Can the planes have a paint change to the bottom of the wings and horizontal stabs?
3 If you can do the paint change on the bottom of the wings how much extra would it cost?
( i'm thinking just metallic silver with checkerboard on the tips of the stabs and wings)
#128
My Feedback: (36)
Melvin,
1) KIts are in fact painted in the mold and have no seams.
2) You can do color flips on any of our schemes.
3) Please email Scott or Pablo with the specific changes you would like to make and you will get a price.
Michael
Michael
#132
My Feedback: (48)
WRONG! Not even close!
WRONG AGAIN!
WRONG AGAIN!
DING DING DING!!!
WRONG!!
WRONG AGAIN!!
WRONG AGAIN!!
DING DING DING!! except designed for Shockwave per our specs.
WRONG AGAIN!
WRONG AGAIN!
DING DING DING!!!
WRONG!!
WRONG AGAIN!!
WRONG AGAIN!!
Keep trying Buddy! I need to hire you as marketing Director. You must of spent hours doing this research!
The stuff you got was the old stuff man. I knew you tried to go around us. Needed to dump that old inventory on you.
#133
My Feedback: (48)
No extra charge!
check out this pic.
Scott
#135
On a serious note & to clear up some confusion - I am the guy who installed Behotec C50F electric gear in my Shockwave. I've had great luck with Behotec air gear and been flying larger jets off grass with their compression struts for years without any issue. When I got my first Shockwave I was hesitant about the extension spring Airtech units so I went with my Behotec plan. All that did was create more work and headache for me. Behotec's are NOT a direct drop in fit. I did the research and ordered what I needed thru Peter at Altecare. Shortly after placing my order I found it posted on their website as a package deal. I am not bashing Peter and he is excellent to deal with but it needs to be noted it is NOT a drop in fit as some may think. Fitting the mains is not a big deal, but the nose has some issues. FYI, I have another Shockwave coming and it will use the stock Airtech's as designed for this jet.
Here is my story & pics to help educate some of you...
#136
Main gear - 200mm is the longest strut Behotec makes for this application. The strut upper body has the 8mm pin hole offset. As delivered the thick side would be on the outboard side in the Shockwave and prevent the strut door from being flush with the wing. This was simply fixed by swapping the lower strut arms to make the thinner side of the upper body be the outboard side. I needed to drill and tap the upper body to attach the door. That was really all I needed for the Behotec mains to fit.
#137
Nose gear - The longest trailing nose strut from Behotec is 216mm. The retract fit right in with no mods but after attaching the strut I found the nose wheel hanging outside the fuselage due to the forward rotation. What I didn't realize until this point was how the Airtech trunion strut attachment is different from standard retracts. The Airtech strut attachment is offset and with gear up it moves the strut leg above the retract thus pulling the trailing wheel inside the fuselage. So to get my Behotec nose to fit right I had a few options - shim the mount plate to kick the wheel up, try a 105 deg trunion or straighten out my trailing strut. During fit tests I noticed the jet sat a little nose down so I thought straightening nose strut would be the easiest and solve both problems. I made a longer plunger for the strut but this obviously made the strut longer which required the nose door opening to be longer. With the nose gear bolted in I fit tested the door. Due to the curve in the fuselage I was having a hard time figuring out hinging with smooth operation. I tried offset hinges and a few other methods before I decided to split the door. Instead of 2 actuators or servos I made a sliding interlocking tab so both doors can be operated by one servo. It works, but involved more thinking and trouble than it was worth in my opinion.
#138
My Feedback: (48)
A lot of things have changed in the last year with our Landing Gear. We never stop improving. I guess this is a great opportunity to officially announce them.
We have a new main frame that is a one piece frame from billet aluminum. no more moving parts called "Block" cnc from a block of billet aluminum
We have a new cylinder design feature. cylinders are now easily serviceable with new design
Nose gear now come with XXL cylinder with new cylinder feature.
We have a new strut design that now allow for wheel to face out. This allows for a very sharp install. see pic. improves look and function. offset strut with upgraded spring
We have another strut design currently in the works. coming soon.
We have a new wheel design. A 3 piece wheel. This is very high quality wheel.
We now offer electric gear for the Shockwave. electric gear do not require an ECU. plug and play. only one I know of with this feature.
We now offer landing gear options that were not previously available.
We now offer Hammer Engines landing gear made especially for the Shockwave. Bespoke Shockwave.
Only available from Elite Aerosports!! ;-)
See pics.
Scott
See pics.
Scott
#139
So in the end I made my Behotec's work as more of an exercise for myself but would not do it again. I already have another Shockwave coming and will not deviate on the gear this time. Elite Aerosports product improvements continue to make the Shockwave the best sport jet on the market.
#140
My Feedback: (57)
See pics.
Scott
See pics.
Scott
It sounds like you guys are doing good things! Will you have electric brakes to compliment the gear?
George
#141
Thanks a lot for all the information!! When i am ready to purchase my Shockwave it will be the yellow scheme just like the one you showed me the bottom of. I will be able to see that ok i think and i will go with your landing gear as well; Thanks for the speedy replys It will be a while before i can order one cause the tax man is comming soon but hopefully this spring i can get one on order.
Mel.
Mel.
#142
My Feedback: (21)
FL
Scott, Pablo and Mike I.E. Elite Aerosports crew,
I have been flying jets for a couple of years now. I dont claim know a lot about jets, but the knowledge in which I have gained from hanging around the guys listed above has been second to none. I have bought and flown three different jets which Elite Aerosports carry. ( Pirotti, Aurora, Shockwave) All have been outstanding quality and design. If they can with stand my carrier landings, then they can with stand anything you put their planes through. I have no stake in company, but rest assure anyone who buys from this company WILL NOT be making a bad mistake on their purchase. Thats all that to be said about that.
#144
Shockwave video from FJ2014
https://youtu.be/TVMV6EKERYk
#145
Just came across this new model.
Looks like bvm quality, but the plane is just too damn big. They need to shrink length by 2 feet atleast and then proportionally everything else.
