Stock CARF Ultra Lightning Pipe
My Feedback: (73)
RE: Stock CARF Ultra Lightning Pipe
Tam pipes are super, and will hold up better than most .. If you have hot starts at over 800 - 900c, then any pipe will deform and need replacing .. The CARF pipes are super tough as they are but as you noted, they are heavier .. is 6oz a big deal on the Lightning ? You want the best, go for the Tam
Voy
Voy
My Feedback: (76)
The only thing i don't' like about TAMS pipe is that you can't use the bypass that comes with the ultra lighting so all that has to be redone, the Tams pipe has a built in Bell mouth.
In the end I just went with the stock pipe as it was simpler. I'm sure someone has made an updated kit (OR tam may even sell this now) that has an updated bypass that works with the Tam Pipe.
