SM F-4 tail hook
My Feedback: (24)
RE: SM F-4 tail hook
Yes, I did it on my small Xtreme Jets F-4. [link=http://www.rcuniverse.com/forum/fb.asp?m=11304949]http://www.rcuniverse.com/forum/fb.asp?m=11304949[/link]
The only problem is that, so far, I haven't been comfortable enough with the plane to think about deploying it flight!
Hopefully in a few more flights (only 7 or 8 so far - few and far-between), I'll get it down and show the hook as well as the 'chute.
Bob
Bob
NJ
Hi Bob,
Thanks for the info.
Can you describe how you hinged the hook.
Also, I was thinking of using an air cylinder rather than a servo and was wondering what your thoughts were.
Thanks again for the info.
Jon
Jon
My Feedback: (24)
Jon,
I used a piece of phenolic sheet to make a tall "horn" that was glued into the hook - at around a 70 degree angle, that would go up into the fuselage. Then I made two plywood supports that went into both sides of the hook, on either side of the horn, and stuck up into the fuselage. I drilled a hole through the hook, from one side to the other, that went through the side of the hook, one plywood support, the phenolic horn, the other plywood support, and the other side of the hook. Through this I inserted a carbon rod as a pivot which was glued to the outside of the hook on both sides - just to keep it in place. Of course the hook itself is hollow, so that is how this pivot structure fits inside the hook itself.
I then cut a hole in the bottom of the fuselage where the hook sits that was just wide enough for the two plywood supports, on either side of the horn, to go through. I made the hole (more like a "slot" actually), long enough so that the horn could pivot the required distance to raise and lower the hook. I inserted the assembly into this slot and Hysol'ed the plywood supports to the inside of the fuselage - being careful not to get any Hysol on the horn or between the horn and the plywood supports.
Once this cured, I could raise and lower the hook by moving the horn forward or aft. The horn was connected to the servo by a cable pushrod, as you see in the pictures.
You could build a similar pivot without the horn in the middle and then use an air cylinder aft of the pivot to raise and lower the hook, but in the end, despite the difficulty in explaining it, the method I used would be simpler - with the benefit that, using the cable pushrod, you can put the actuating device, either servo or air cylinder in a place where it can be easily accessed.
Bob
Bob
My Feedback: (21)
Jon
I have a cable/servo driven tailhook similar to Bob's on my BVM F4. (cudos to Uncle Joe who was the original owner for setting it up)
works and looks great
cheers
cheers
ORIGINAL: rhklenke
Jon,
I used a piece of phenolic sheet to make a tall ''horn'' that was glued into the hook - at around a 70 degree angle, that would go up into the fuselage. Then I made two plywood supports that went into both sides of the hook, on either side of the horn, and stuck up into the fuselage. I drilled a hole through the hook, from one side to the other, that went through the side of the hook, one plywood support, the phenolic horn, the other plywood support, and the other side of the hook. Through this I inserted a carbon rod as a pivot which was glued to the outside of the hook on both sides - just to keep it in place. Of course the hook itself is hollow, so that is how this pivot structure fits inside the hook itself.
I then cut a hole in the bottom of the fuselage where the hook sits that was just wide enough for the two plywood supports, on either side of the horn, to go through. I made the hole (more like a ''slot'' actually), long enough so that the horn could pivot the required distance to raise and lower the hook. I inserted the assembly into this slot and Hysol'ed the plywood supports to the inside of the fuselage - being careful not to get any Hysol on the horn or between the horn and the plywood supports.
Bob
Jon,
Bob
