Bobcat Composite / Jetcat P90RX Help Needed with Turbine Mount
My Feedback: (114)
Trying to mount a new Jetcat P90 to a Bobcat Composite...there are threaded holes in the aluminum spacer attached to the carbon flexplate on the jet. Unfortunately the holes don't go all the way through the bottom of the jet so I am having difficulty figuring out how to perfectly locate the holes on the aluminum mount attached to the Jetcat. There must be some good techniques out there...Any help would be appreciated. Will try and get a pic up later.
Thx
Thx
The 90 is the same case as the P-80...so exactly the same proceedure.
You can put in 4 set screws,add paint to the top face and carefully place the mount down on them.
Drill a small hole and check position. Then open.
Or vernier. measure, mark, drill. Its a square pattern
Dave
Dave
