Ripmax Xcalibur Sports jet
#2226
They do look good Peter. I see one comment about carbonfibre and your Rx. I know Dave covered this point previously by saying "position the remote receivers as far apart as possible and there should be no issues".
I also remebered seeing a post about loose screws on the wheels and retracts. Having a few minutes free. I gave a few screws a quick tweek with a screwdriver. OMG! I ended up removing and adding some loctite threadlock to 17 of the 18 screws on the wheels and three other screws on the retract bodies. Most of the screws at best were finger tight or worse.
its good to check!
its good to check!
#2227
Thank you Stuart
Yes , you´re right , carbon fiber blocks RX signal , so it´s a good idea to separate satelites ( I have 2 plus one more acting as a wireless switch )( I fly with Jeti DS 16) and spread the antennas , so as they are 90 degrees respet each other , I intend to locate one satellite by the fuel tank, and the other probably by the nose , and one of those antennas pointing 45 degrees downwards and the other 45 degrees upwards.
As a seasoned helicopter pilot , I have learnd the hard way , to check and loctite all screws on new eqipment , so this one won´t be the exception :-) specially afyter reading some threads about main wheels loosing some screws , better safe than sorry.
#2229
Afternoon Gentlemen,
I know this question as been asked before but unless I re-read the whole thread again it will take me ages. so apologies for repeating this.....
Can someone explain the purpose of putting electrical tape around the spring on the retracts? Does it soften the action? or some other purpose
regards
Stuart
regards
Stuart
#2230
Hi stuart
The reason(as I understand it) is to keep the brake air pressure line from moving during extension and retraction and get caught between gear strut and the wing underside.
Probably I´m worng, but that´s how I see it
Peter
Peter
#2231
Main reason is to make main springs more "hard" thus having a model on the ground less side-tilting
I'm using this with my Xcal standard main gears spings since almost 3 years, simple and effective indeed!
#2232
Progress
Few More llittle jobs done.
Finally got the courage to drill holes and run airlines. Then glued some 3d printed line tidies and have just started doing the steering close loop wires.
The rear retracts are fitted and all bolts have had some loctite added along with all air lines wired securely.
#2233
As Dennis said it takes some of the leg leverage away from the spring. Makes the model more stable on the ground too. It was developed for the original Flash to legs by a genius ;-),really it was noticed after starting to tape the brake lines to the leg and an improvement noticed.
#2234
Update
Today I have moved slowly forward. After gluing the cable tidies into place overnight, today I ran the lines and wirelocked everyone. I think that may be alittle over the top but better safe than sorry.
#2235
Afternoon gents, I am trying to find a few more of the Barbed "T" air fittings that are a match for the ones in this kit. I can find BVM ones but they are black and not purple. Any help?
Stuart
Stuart
#2238
Air Tank Mount
Well as no one came forward with the files for the air tank mount refered to earlier in this thread. I decided to draw my own.
#2240
My plan is to place the sensor switch at the front and so minimise the two battery extension leads. Im sure having power leads as you suggest would not be a wise thing to do.
Hope this makes sense.
#2242
The Guru
After having a short conversation with the Guru of all things Xcalibur, Dave Wilshere. I decided to redraw the airtank mount and remove as much extraneous weight as possible. So with this task in hand, here is my MKII AirTank Mount. The original came out at 196grams.
Item Weights
2x Air Tank 66g
Powerbox Sensor Switch 36g
Valve and Pressure Gauge 10g
Hardware Total (112g)
The new total is 154g so I have saved 42g. Doesnt seem alot but as DW explained in the words of that well known supermarket "Every Little Helps!"
Item Weights
2x Air Tank 66g
#2245
Carbon Covers
I have to say, anyone following this thread and thinking about getting a Ripmax Xcalibur. Stop thinking and get one ordered. I know a great place (motors and Rotors) here in the UK to get one.
It is a very relaxed build. Nothing of note for anyone with the modest of building skills. Mind you if your getting an RC Jet, I guess you have a history in RC or are a missing pensioner from the Hatton Garden Gang!.
I have just finished adding a little bling in the form of Carbon Fibre tubing to the pushrods. N.B wear gloves, 3mm ID carbon tubing is a tight fit. I had to push moderately and ended up with a CF splinter. OUCH!
enjoy
enjoy
#2246
Absolutely right Stuart
This is an excellent jet model which not only looks great, but flies great as well , and with a wide speed envelope , for what I can see,
DW is "the man" when it comes to Xcalibur .
Peter
Peter
#2248
Control Horns
Well, while adding some CF tubes to the pushrods it became apparent I had two missing control horns. A quick call to DW @ Motors and Rotors, I found out that "standard" control horns are not correct. Apparently the ones in the Xcalibur Kit are made from plastic that is not effected by the turbine exhaust temperatures and do not become brittle over time. I was also informed that they are not supplied as an extra or spare.
DW said he would attempt to get some from Ripmax.
well three days later (today) postie delivered me direct from Ripmax a complete set of control horns.
and more surprisingly Free of Charge.
Thats amazing customer services and a clear reason to deal with Ripmax and Motors & Rotors. THANK YOU
