Reload this Page >
Ripmax Xcalibur Sports jet
Old 12-08-2017, 07:33 AM
  #2251
sauntson
Originally Posted by Dave Wilshere
Only thing is your horn is going to constantly twist. The horn and linkage should be 90 degrees, so arm above servo and angled back....
Hi Dave
Is this what you mean?
Name:	horn placement.gif
Old 12-08-2017, 08:40 AM
  #2252
taz-manian
Well , no big deal
actually I don't know what was I thinking about when I did it, but I'll get it fixed in no time
Old 12-08-2017, 01:13 PM
  #2253
sauntson
Default Rudder Control Rod
Can someone check and advise accordingly?
Name:	rudder control rod.gif
Old 12-09-2017, 01:16 AM
  #2254
Dave Wilshere
Yes, that’s what you need.
D
Old 12-09-2017, 12:35 PM
  #2255
sauntson
Can anyone confirm the thickness of wiring for servo extensions?
Ive done some googling and have found suggestions from 22AWG - 28AWG
Like most internet responses, they leave you more confused
cheers
Old 12-09-2017, 01:20 PM
  #2256
Dave Wilshere
0.35mm sq Like Powerbox wire. Lightest, fire proof. I use std JR/Graupner leads usually since std lengths work.
Old 12-09-2017, 02:05 PM
  #2257
sauntson
LOL my point exactly,
0.35mm sq converts to 22awg in wire gauge, when searching for Graupner Servo extensions they state 25 awg wire.
confused.com
Old 12-10-2017, 03:40 AM
  #2258
Dave Wilshere
Std or heavy duty Graupner leads? They have two. Think they call the HD Gold leads
Old 12-10-2017, 06:20 AM
  #2259
sauntson
Apologies DW, Thank you for your reply, I searched for Std and not Heavy duty as you wrote
" I use std JR/Graupner"
I now have that little more knowledge sir
Regards
Old 12-10-2017, 08:46 AM
  #2260
Dave Wilshere
Think you found the USA listing which showed some cheap sudo silicon leads Graupner offered after they reopened. I have some I wouldn’t sell. They are junk.
Old 12-10-2017, 09:00 AM
  #2261
sauntson
You could be right Dave...... Damn these sausage fingers!
Old 12-10-2017, 10:38 AM
  #2262
sauntson
Default Nose Retract
Another question, is there a way to line up the front retract steering wires?
What is the purpose of the silicon on the front retract, circles in the attached picture?
Thank you in advance
Name:	Nose Retract.gif
Old 12-10-2017, 11:29 AM
  #2263
Dave Wilshere
By eye is good enough, unless the mains are 100% matched on toe in you will need steering. So trim on the ground. I run the wires slightly slack, the trailing wheel tracks.
The silicon is something I use to stop the closed loop wire swinging around on the pin. It still steers, but the silicon will keep the wires inline. I slot the face vertically where the wires protrude
Old 12-10-2017, 12:44 PM
  #2264
sauntson
Finally took the plunge and installed the nose wheel, steering wires and air lines. The moral of this exercise is as Dave said. "steadily eyeing up", marking 3 times, checking and rechecking before you do anything.
very well pleased
Name:	Nose Steering.gif
ID:	2247383   Click image for larger version
Name:	Nose Retract Front air line.gif
ID:	2247384   Click image for larger version
Name:	Nose retract rear air line.gif
ID:	2247385   Click image for larger version
Name:	First time on wheels.gif
Old 12-11-2017, 10:06 AM
  #2265
sauntson
Default Air Lines Install
I have today carried out a few more tasks. Run the remainder of the air lines and installed line tidies.
The Behotec Brake /Retract valve as been installed. see Pictures and lines wire locked
I would like to fit connectors which would allow me to remove the side plate and so behotec valve, without removing all air lines.
Would the brass connectors stay airtight? I know they are used for wing retracts to fuselage joints. Just need to know if they can be left connected 24/7 and remain airtight.
any other suggetions greatfully received
cheers
Name:	Beohtec Valve.gif
Old 12-11-2017, 12:13 PM
  #2266
Dave Wilshere
I've not had to remove my plates in 3 1/2 years. But I'd unscrew the valve and slide the plate out if you ever have too...Joints are a No no
Old 12-17-2017, 07:32 AM
  #2267
Si_B
Si_B's Avatar
Does anyone have the product codes for the correct film to match the yellow sport scheme? I'm after the dark blue and the yellow used on the booms. Recovering for a friend, have a yellow which is close, but nothing near to the blue. He wants it to look like stock, so would prefer to have the exact matches if possible.
Cheers,
Simon
Old 12-17-2017, 08:11 AM
  #2268
sauntson
Default PM
Cheers,
Simon
You have a PM Simon
Old 12-21-2017, 07:28 AM
  #2269
sauntson
Default Paint Match
Greetings Gentlemen
I have read on this thread about members needing to find the film that is as close a match as can be expected for the RAF Scheme. So taking this to the next level. I have today had the paint (gelcoat) Spectro-analysed with the following results. I will upload the paint codes and telephone number of the company, once I have confirmed the results.
So keep checking back.
Regards
Name:	Xcalibur Blue 1.jpg
ID:	2248226   Click image for larger version
Name:	Xcalibur Red 2.jpg
Old 12-21-2017, 11:59 PM
  #2270
sauntson
YAY!
If any of you have this Xcalibur in the RAF Scheme. You will know around the nose cone the finish gets damaged very easily and no longer as straight lines.
Using the paint I collected yesterday and a very small brush. After masking a line, I carefully added a small amount of paint. Let it dry over night and have just given is a quick compounding.
resulting below
Name:	scratch removed.jpg
Old 12-22-2017, 12:46 AM
  #2271
sauntson
Default Colour Paint Match details
Morning Gentlemen
As promised, the pictures below have all the details you require to get a perfect match. The Guys @ Car Colour Services were very easy to deal with and showed a real interest in helping. They will post so even if your not in the UK, you can still get a perfect match for your airframe
MERRY CHRISTMAS
Car Colour Services Ltd.
92-94 Mawney Road,
Romford
Essex
RM7 7JB
Tel : 01708 746 468
Email : [email protected]
Opening Times:
Monday – Friday 8:30am – 5pm
Saturday 9am – 1pm
Name:	red color code.jpg
ID:	2248346   Click image for larger version
Old 12-22-2017, 09:16 AM
  #2272
Dave Wilshere
Each film batch varies very slightly...so its not so cut and tried! Also it fades in sunlight, so older models will be different again!
Happy Xmas :-)
Old 12-23-2017, 03:05 PM
  #2273
sauntson
Just to clarify, The colours I had analysed is for the gelcoat. NOT the film covering. That subject as already been covered using a Monokote Film.....
I also feel, if an Xcalibur got to be that old it needed touching up. I think it would need more work than a simple restoration.......
Old 12-23-2017, 11:17 PM
  #2274
damagedgoodes
Yep sometimes its more than a simple film touch up
ID:	2248545   Click image for larger version
ID:	2248546   Click image for larger version
ID:	2248547   Click image for larger version
ID:	2248548   Click image for larger version
Old 12-24-2017, 12:30 AM
  #2275
Signofinfinity
Nice!! My compliments!
Are the wooden parts glasses and sprayed?
George
