Tu-16 Badger - Cold War soldiers
#32
I apologize for the long silence. I was distracted by different concerns for a long time.
Now I can go back to work on the model. Last week vykleil turbine inlet. This larger tube approximately three feet in length and 4 inch diameter. Use 2 layers of fiberglass. Turned half a pound each. The next stage is planned to install them in place and production input of the inlet.
#38
Maybe in the spring. In this model, there are some places not well defined. Troubleshooting will take some time.
Perhaps we will be offering short sets, napilennye of plywood and a set of diagrams for assembly. Some difficulties is the main steering gear landing gear legs.
Production of the first samples also revealed some problems that need to be addressed. I'll write about it later.
#40
Great project.
It is good to see someone cutting wood and building a jet from scratch. A rare achievement.
What is your target weight (without fuel)?
Do you intend to use two turbines with 100N thrust each? What make of turbines?
#42
Good day to all!
More ...
We finish trim the top of the left half of the wing and begin to assemble the right half. Console will be held at the carboxylic pipes 1 1/4 inches. Before final assembly customize the root rib and the wing center section. The aircraft is gradually taking its shape ...
More ...
#49
Hallo zusammen!
Tapezierte Balsa oberen Teil des rechten Flügels. Paste Federtasche im Zentrum Schnitt des Rohres. Carbon Federmäppchen aus Mitte-sehr hart, fast monolithisch. Ich konnte nicht widerstehen und nahm ein Bild von dem, was passiert ist. Eine Reihe von Sperrholz und Balsa Ausgangs an wie ein Flugzeug zu suchen.
