Skymaster F16 1/6th scale 2g rudder question
So I have been watching several videos on this model and have noticed some use the exposed rudder servo setup and others the internal. Being a scale guy I would much more prefer to go internal if safely possible. It has been mentioned that the newer 2G kit has been upgraded and Anton in an e-mail said it is strong enough to go with internal. I will be using a AMT Pegasus HP that is set at about 38lbs mostly because I have the engine and for my type of flying should give me the performance to suit me. Later I could always shoe in a P200 if needed. So just looking for anyone that has been flying the newer 2G model and what setup they used. I have backtracked some older threads and have seen it both ways. Please understand I'm only interested in this model and not a comparison to other F-16 kits.
Thanks in advance
Kelly
Thanks in advance
Kelly
Hey Kelly,
Did u have any luck get info on the rudder set up? A mate of mine is just starting to put together my G2 F16 and we are wondering what set up to go with.
Im not sure if the G1 is the same but mine has the rudder servo mounted in the top of the fuse not the fin itself.
Maybe Dantley or Torr will chime in. I know they have had a couple.
I am going with either a 180RX or 200.
Kind Regards
Levi
Kind Regards
Levi
Dantley's way is the best I have seen in the external setup. I won't have the big block engine ( P-180/P-200) but more than likely an AMT Pegasus HP as I have one sitting in the box that will need a home. I guess when I get the model I will look it over carefully and see if it can be done/improved enough to be safe otherwise I will go with this setup as well. I know guys are making it work but like Dantley said it depends on how fast your pushing it.
Thanks for posting that picture Dantley
