Merlin 140X FOD Screen
Hello all,
I was considering buying a Merlin 140X (with the brushless starter) and I've just asked Gaspar if he makes a FOD screen to fit and he has replied (exceptionally quickly) that he doesn't.
Does anyone know of a FOD screen that will fit this turbine or one that is easy to mod to fit?
I still can't quite understand why manufacturer's don't supply what is almost universally considered to be an essential piece of equipment. Jetcat were a little slow on the uptake but the ones that they supply now have been excellent for the turbines I have used them on, and the Wren solution is also excellent. I hate to buy an expensive model, with an expensive turbine and then bodge a tea strainer on to the front of the engine.
Gaspar told us to use a Hobby King FOD guard for his 160, it will fit with a little fettling. Its a bit crap but better than tea strainer, I completely agree with you though!
My Feedback: (16)
I bought these from Todd and modified them. http://www.dreamworksrc.com/catalog/...reen-98-X-81Mm They are held on with an O ring. Remove the white center ring, slit the screen in quarters 30 mm from the base, then fold the quarters inward. You can either place the O ring over the excess screen which will now be along the starter or modify the center ring and reuse it. The project takes apx. 20 minutes.
Well it doesn't seem like there are many decent options
It looks like Jets-Munt are going to lose a sale of a several thousand dollar turbine, for the sake of not providing a part that would probably cost them no more than $20 to make It seems like a strange business philosophy to me but maybe there's a reason that I'm not aware of.
Hi Darren,
I have used a couple of the Hobbyking ones. They only thing I had to supply was a fat O-ring. Otherwise they are the best quality ones I have come accross, except for the Wren integral ones. This is what Gaspar used to supply. I think that they do a smaller size too.
Best
John
Best
John
If you could Todd, that would be great. I had thought that the starter pod for the M140X had 'ears' on it that might make fitting a FOD difficult but I've just realised that the picture I was looking at was the VT80. Maybe fitting a FOD to the 140X isn't as hard as I initially thought?
My Feedback: (24)
Not at all, very simple. The main issue with fitting a FOD screen on the latest Merlin releases is the small diameter of his new starter motors. Looks like I am sold out of the Jetcat P-60 screen at the moment but will document the modification as soon as inventory arrives.
Todd
Todd
