Behotec C36-V Retract Valve
My Feedback: (12)
Has anybody setup and programmed a behotec C36-v retract valve on a JR 12X? I have the valve working for up and down but I am having a hard time setting up the braking function. I would like to set the right lever (Flap Lever) to be the brake but I dont think I am going to be able to program it to move the retract servo just the little bit to engage the brakes.
How have you set the valve now?
Short arm 3/8" 10mm radius? Reduce the Travel down to say 80-20% on gear channel and adjust spline position to give retarct only movement.
Program mix 1 RLVR-GEAR and adjust the + percentage to give you additional movement...
Dave
Dave
My Feedback: (12)
I have the travel reduced already and the gear valve functioning as it should. I tried to mix it but was not able to assign just the switch to do the additional movement. I will look at it again though, thanks Dave!
