Kero V Gas
Banned
Kero V Gas
Now that Kero start has been around for some time I was wondering if people honestly prefer it to gas start. For me all the faff with the battery types and the often limited number of starts you get make it a worse option over gas start. Also the cost of service of a kero burner over a glow plug is in my view a disadvantage.
What do others feel ?
Shaz
Banned
Easy choice for me also. Kero start all the way. No problem with them and also just got a K-180G with the valves built into the turbine. Makes the install very easy and neat
Kero start is defiantly easier but takes longer to start.
Gas is quicker but you have to carry to fuels.
I believe both are reliable so it really comes down to preference.
In everything in life there is pros and cons in everything.
PA
Personally.... I've seen issues with starting on Kero a bunch of times over the last year or so. Everything from a smoldering start (and no fire) to full on flame throwers. SO... because of that... I'm not sold on it.
As far as "Why carry 2 fuels".... I already carry so much extra junk when flying turbines, it's not a big deal to have a bottle of propane.
I prefer gas starts. Besides... The Kero start system made the engines more expensive by $100 or more.
Banned
What about the fact that with Kero start if you have a problem you only get about 4 tries out of the battery
If you have a bigger start problem it has to go back to the manufacturer
If you ruin a kero burner it costs well loads of $$$$$ whereas a glow plug is only $5
Is there another and ?
My Feedback: (22)
I've had both, both work fine, but personally, I like the gas start, hell, I still like my Air Start Pegasus, makes me feel like I'm part of the start up, forces me to monitor everything, and it starts faster. As I say, I've had both, really doesn't make much difference to me but all my engines currently are propane start. I like just using the green coleman propane better than powermax too, easier to find, cheaper, and I've had so many cans of powermax that after I put the valve on I can't take it off without the can splooging out everywhere, and I hate the idea of the can in my flightbox with the valve on it!
PA
Basically... those are all the reasons why, I still have gas start. (I'm cheap)
My engines are all gas start & this suits me fine as its what I'm used to.
To me the biggest advantage of gas start is it's usually possible to fix problems with them
at the field so it doesn't spoil a days flying or a weekend away at a jet meet if things do go wrong.
You can save a bit of weight with a smaller battery as well & if the choice is available the gas start
option tends to be cheaper.
If I was ordering a new engine it would also be gas start for the above reasons.
But if an engine was attractive enough to me & it was kero start only it would not worry me at all to
buy it, I have no gas start or kero start only hang ups, I just want the things to work.
Like most new things I think kero start has had it's development problems but they seem fine now.
I tend not to be an 'early adopter', I like to let the trendsetters work out the bugs!
John.
John.
