Jeti-duplex-ds-16-2.4-ghz
#3376
Its very simple.... first you creat a retract sequence once you have created the sequence and all works then you do the following...
In Free mixes you create a mix Rudder to Nose wheel set the percentage of the mix to the amount of travel you like.. you can have different travel for each flight mode.... then in second page of the mix you activate the mix using the retract switch in a way that when the gears are down the mix is activated and you see a check mark.. when the gears are up the mix is deactivated ...
David
David
Your kind response reminds me that the Jeti youtube about the Jeti sequencer is about lights on a night plane and I was not able to translate that to a landing gear scenario.
How does one create a Landing gear sequence?
Example: Landing gear, steering servo, nose door that remains open when gear is down
Gear Down:
1. Door opens
2. Gear goes to landing position (down)
3. nose gear is able to steer
Gear Up:
1. Steering is centered
2. Gear goes to flight position (up)
3. Door is closed
thank you again for helping we new guys to the Jedi fold opps Jeti
Cheers Thank you
#3377
I seem to have run into a problem with an mbar sensor. It had been working fine but, now reads zero air pressure. If I look at it through the Jeti box emulator on DS16, it again reads 0, scrolling through, I get a message that the" mbar is not calibrated".
Is there a way to calibrate the mbar or is my mbar toast?
Mike
Mike
#3378
Mike
Mike
Mike, the bottom part of the fitting where the air line attaches, is part of the circuit board.
It doesn't take much to damage the contacts.
That could probably be the problem.
Jack
#3379
Thank you Mr. David
Gear Down:
1. Door opens
Gear Up:
3. Door is closed
Cheers Thank you
Gear Down:
1. Door opens
Gear Up:
3. Door is closed
Cheers Thank you
First create a mix from rudder to NWS that is activated by the retract switch.
Then in the sequencer menu you will create a door sequence that will look "L" shaped.
#3382
Have you seen the CB adapter?
https://system.na3.netsuite.com/core...77117&_xt=.pdf
JETI COMPATIBLE PROTOCOL CONVERTER. JETCAT ECU 6X 10X EXSUPPORT
#3385
My Feedback: (40)
Go to the Jeti section on the Espirit website here: Jeti Video and look for the Jeti Short video titled "Telemetry & Data Display. It explains how to accomplish what you're asking about.
#3386
My Feedback: (7)
Correct. This is what you need: Dreamworks Model Products LLC
#3387
My Feedback: (40)
The telemetry adapter in your link is for Jet Central and I believe he needs one for a Jet Cat so he'll need a different telemetry adapter like this one https://www.dreamworksrc.com/catalog/Search-Results?osCsid=3d056742c813b7d786222dfbfe91e9dc&keywords=JJXC
For some reason your link above is not connecting for me. I think this is the adapter he needs: Dreamworks Model Products LLC
#3388
My Feedback: (7)
You're right Wayne, my bad. I picked the wrong one.
#3390
You can either email him or contact via web contact page.
http://www.cb-elektronics.com/contact.html
[email protected]
Here is his website
CB Elektronics
#3391
Thanks to Danny (at Esprit) I got my gyro working using the "Flight mode Trims". Also discovered how the +Delay- in the Butterfly mode works and got my ailerons and elevators move at the same speed as the flaps move down... What a smart transmitter... I'm liking it more and learn more every time I use it... I will have a whole bunch of JR and Spektrum DSMX receivers for sale.. Very soon......
David
#3393
"Butterfly/Crow Delay The time delay function can help smooth the transition from one state to another. Function of the “Delay” is to slow down the movement of the control surfaces during the change. Increasing the number on the positive side “+” slows the deployment while increasing the number on the negative side “-” slows return of the surfaces to their original positions."
#3394
My Feedback: (7)
But won't that delay everything controlled by the flight mode? For example if I have separate gyro settings for flight mode (I don't just using this for an example) I might not want my gyro to transition slower but do want my flaps and elevator compensation delayed. Besides that, having a feature like +/- delay on butterfly that doesn't work (or I don't understand how to use it) just bugs me; it must function in some scenario like the manual describes:
#3395
Thanks F1 and Wayne. I've got my flap delay working the way I like it now using Butterfly mix. Now I have another question:
At some point during my model set up I changed something that causes the trim screen to appear every time I start the transmitter, any idea what did that and if there's a way to disable it.
Thanks again for all your help.
David
David
#3397
If you still like to use a switch, get a two position spring loaded switch
David
#3399
My Feedback: (7)
The trim menu shows up automatically when a trim changes so if you have something that would cause a trim change on power up (sequencer ??) then that may do it. I can't think of a way to directly assign the trim menu to activate with a switch but that doesn't mean such a selection doesn't exist.
#3400
Hi Wayne... I had a question on what you mentioned above. On your jets when setting throttle trim to a 2-position switch, did you have to retrain the turbine ecu to recognize the switch as trim-up and trim-down?
Rob
Rob
