Jeti-duplex-ds-16-2.4-ghz
#2127
+1 on that, this is something that would be nice to have as part of Jeti future update with a special file that will not get changed when updates comes along. This is the one part I am not too crazy about is having to redo the JSN file everytime an update comes along.
#2128
I just received a REX12 receiver, but when I try Device Explorer on my DS-16, I get;
Error: File corrupted
REX12.bin, Line: 0
I have updated the Devices folder on the Tx with the latest content from Jeti web-site, which includes the REX receiver files, and I'm running the latest Tx s/w (3.02).
Help appreciated.
Paul
REX12.bin, Line: 0
Help appreciated.
Paul
#2130
I'm trying to set up a Double Path receiver system with a R11 and a R3/RSW.
I've gone through previous posts and set up both receivers, with the R11 as primary, and the R3/RSW as secondary.
Questions;
1) With the R11 SAT/11 port set to PPM Input, what output format do you set the R3/RSW to? Not sure if it should be JETIBOX & Servo, PPM Positive or EX Bus.
2) I've read that the R3/RSW is connected to the primary Rx via output pin #4/ Ext. as a satellite, but if you set the R3/RSW output format to PPM, then the PPM output is set on pin #3, which is the switch function.
2) If set to output PPM, do you have to set the number of PPM channels to match that of the primary Rx, as it defaults to 8 channels?
3) How do you prove that the primary Rx is getting the correct data format from the R3/RSW to be able to use the secondary Rx if the primary Rx antennas get blanked?
Using the Morse code 'S' for loss of PPM signal alarm, I can get that to trigger by pulling the R11 to R3/RSW link, but with the R3/RSW connected normally (pin #4/Ext.), that alarm does not trigger if I change the R3/RSW output format between JETIBOZ & Servo, PPM or EX Bus.
Whilst the R3/RSW is reporting antenna strength directly back to the Tx, what test is there to show that the R3/RSW will drive a servo connected to the R11?
Paul
Questions;
Paul
#2131
Questions;
Paul
Questions;
Paul
r11 ppm input. R3 ppm output with the failsafe off, port 3 on the r3
Serial link on the r3 should be set to ppm positive, under ppm setting set the number if channels needed, ppm/udi mode should be ser to direct
#2133
Hi all,
Got to fly my Jeti last weekend on my F16. All went well but I am wondering if there is a log of my flight somewhere in the transmitter? I did not set anything up specifically but didn't know if there will be a log each time like my Weatronic receiver.
Dave
Dave
Zb/Jeti USA
Have a look here:
https://www.youtube.com/watch?v=Uj2VEV5NUr4
#2134
My Feedback: (7)
Hi all,
Dave
Dave
#2137
Make a backup before you start:
A. Create a new flight condition, switchable on the designated cortex on/off switch (not the flaps switch).
B. While in the condition which you want the gyro off, Delink the cortex gain from the flaps, i.e. no switch.
C. Instead map the cortex gain value to an offset value which equates to shutting off the gyro.
#2138
Stan... It's a good idea to have your flap switch as your flight mode switch... So you have flight mode 1..as flaps up, flight mode 2.. As take off flaps, and flight mode 3.. As landing flaps... Then assign another switch to your gyro. That same gyro switch can also be your dual rate switch since you need to have more expo when gyro is off and less expo when gyro is on.
In the gyro menu make sure you have "separate" mode for each flight mode so you can set different gain at each position of your flight modes. Keep in mind that you have to set the gain to 0 in each flight mode when the gyro switch is in the off position...
PM me me if you need detail walk through....
David
David
#2139
David
David
The Jeti flight mode is so versatile, We are not usually trained in using flight modes as a condition for other than the usual landing, take off, 3D but with Jeti you can use it in many more ways since they are mutually exclusive depending on the location on the list.
#2140
to turn off the gyro, Keep it simple..
Set up a simple mix on a switch or knob..
Mix Gain to Gain on itself. Use a value of 0(gyro on) and -100(gyro off). It will zero out the gain instantly, locking out the gyro.. every one of my setups have this..
The reason this works best is because the Free mixes are the last thing that happens in the processing chain of the signals, so no matter what gain you are using, the input mixes back on itself and the result is no gain.
on the DS, I added a voice alert that says "Killed Gyro, Killed Gyro"
If you are using the cortex, the light will go Red instantly..
#2141
Well my mind is getting old, not me of course. I did exactly what you are saying 6 months ago in free mixes and forgot I had did that. I never looked at the cortex light to check to see it turn red.
When I use the other switch to shut the gyro off the light on the gyro does go to red.
Too much stuff to remember guys
Thanks guys for your suggestions, Maybe someone else will benefit from your explanation.
Stan
#2142
Don't feel bad I had to ask on an other forum why while putting a new Mezon in a plane I had the red wires going to the CB200 disconnected on the older one.
I knew why when I did it originally but forgot.
(Answer: The CB200 gets its power from the batteries not from my Mezon which powers the motor)
#2145
HI all, I just bought a Eflite T-28 electric powered, to be my platform for learning the ins and outs of my DS-16. I have the CB 200 and need to know where I get the power to run all the servos from, is it from the throttle lead from the ESC.
Pics would be good.
Rcpete
Pics would be good.
Rcpete
Otherwise, it will require a Y Cord from the throttle wire, and you will have to cut one end off, and rewire it so that it provides power to the multiplex port, and a single signal wire to the throttle servo output port..
I just used a small A123 battery when I tested mine and stuffed it into the cockpit..
#2149
