GR180 Turbine drawings
Hi Gerald ,
first I want to thank you for the plans it`s a really good move.
second I want to ask you about a compressor wheel that can replace the "Schwitzer 316954" because it`s really hard to be found even on the websites , if there is a garrett compressor wheel can replace it without changing the other parts , it would be much easier to be found at any car maintenance center.
thank you.
thank you.
Best regards,
Gerald
Just throwing out here, as I am currently building a GR130 (albeit slowly) and not a GR180 :
For my GR130 I have found a Garrett TO4B 8blade that match the dimensions very closely.
Part number 409179-0018
OH
Sorry for digging up an old thread, but wanted to post in case anyone else stumbled on this. The wheel mr rutten used is still available in the aftermarket. The world wide maker of billet compressors, KTS, makes it, KTS p/n S224. You can't buy direct, only from a dealer. If you can't find a dealer i can get them.
#32
Compressor Wheel - 316954
#34
You can download the plan from Gerald's website. Please note that you will require some experience on machining and understanding the drawing and then improvising when needed.
#35
Yes right. I checked the links, look like its down for now.
Please find a copy of GR180 attached here. I am re-sharing in the same spirit as Gerald did and its his content which should not be sold. Treat it experimental and use with caution (Turbine spins at high speed, be careful)
Hope you find this useful and credit to the original owner. Enjoy !!
https://drive.google.com/file/d/1jbZ...ew?usp=sharing
MansurCetinkaya (07-05-2023)
#38
This is GR180 and it has the PDF files as well. Please download the zip and then extract, you will see them. G Drive is not showing all files as such.
The name of the file I corrected now.
