Reload this Page >
Its Coming!!!! Skymaster 1/5 F-16 Arf Plus Pro
Old 12-10-2014, 07:14 AM
  #301
pilot tw
the 20kg thrust for the F-16 1/5 without the ordinance is perfect, but i think the P-300 with the full ordinance should be much better, i will ask Likai install the all ordinance in his F-16 1/5 to test fly again soon,
Old 12-10-2014, 08:49 AM
  #302
jetpilot
My Feedback: (48)
jetpilot's Avatar
I wouldn't recommend putting a 300 in this unless you've speed tested it over 250!! plus your adding a ton of weight with the motor!
I would think a 210 will be plenty. P200 or Behotec 220 max.
Scott
Old 12-10-2014, 03:07 PM
  #303
RonTins
Originally Posted by pilot tw
yes, just confirm it, it is "pointy"
Wonderful!!!
Old 12-10-2014, 06:22 PM
  #304
Pepperpete
Pepperpete's Avatar
What exactly do you base this on? She's not a small bird and extra weight isn't going to hurt it like it would with something that has much less wing area. Heck she can already high alpha at 40kph so I think I can land her a bit hotter without worrying about wingloading. I think we need to wait for Anton to test this bird with a P300 or equivalent and let him be the judge. With a 200 I find the bird to be beautiful but appears slow.
Also remember that at 22kg (48 pounds) DRY without the speed break, working canopy or pilot installed (which will add more weight), a K210 will fly the bird but will be marginal at 46 pounds thrust. This isn't the wet weight either so the fuel adds on top of that total as well. It ends up this bird is nowhere near 1 to 1 ratio for flight which is what I prefer.
Personally there is no way I would want to fly this bird on anything less than a big beefy turbine. Especially with weapons onboard.
Old 12-10-2014, 06:47 PM
  #305
jetpilot
My Feedback: (48)
jetpilot's Avatar
Just basing it off 2 other 1/5th scale f16 ive owned. no useful data I suppose. oh and the fact he hasn't gone over 200mph yet. Oh and not to mention going over 55 lbs wet requires a lot of other requirements over here.
A K210 will never be marginal on this jet. Will be perfect. Behotec 220 nice as well. Still needs to be tested at 250mph and the K210 will do that easy.
Scott
Old 12-10-2014, 06:51 PM
  #306
Pepperpete
Pepperpete's Avatar
Not every country has the same size and weight restrictions that the US has. In that regard we are very lucky (for now). And yes I do agree it needs testing as I said in my above post. If a K210 will do 250MPH I would be happy for sure but I tend to aim for 1 to 1 on Fighter Jets. It's just my personal preference. But I won't be doing that at all unless Anton gives the green light that it's safe.
Old 12-10-2014, 07:15 PM
  #307
pilot tw
I will send the full ordinance set to Likai this week and ask him install to his F-16 1/5 then I will back Taiwan test fly it by K210 again soon, let's see it fly with full ordinance by K210 first,
Old 12-10-2014, 09:01 PM
  #308
Pepperpete
Pepperpete's Avatar
Sounds like a plan!
Old 12-13-2014, 01:35 AM
  #309
pilot tw
good news, the F-16 1/5 new record 320km/h (200mph) by K210 , on last Sunday .
after the Hundred of flight tests on 1:5 F-16. Today when Likai continue to test flying, but the aluminum monut on slat servo has crack, fortunately, we made locating pin,
although slat servo on one side fall off, F-16 finished flight and land safely under control. Later we check the reason and found normal tranditional servo monut can not work long enough and strong enough to fit the completely new slat design by likai.
Though it can be flied more than hunderd flights,the alumium servo mount still fail after these times of test.
We fortunately found this issue and surely will change to 7075 aluminum material before delivery kits to customers
Old 12-13-2014, 03:43 AM
  #310
TJPro351
My Feedback: (8)
TJPro351's Avatar
Another reason why Skymaster is a top notch company, test flight after test flight after test flight. I'm sure the find was because of the number of test flights and not just one 200mph flight. Excellent job Anton and Likai!
Old 12-13-2014, 06:10 AM
  #311
flytmates
Nice job Anton, glad to know all the bugs are being worked out. Cant wait to get mine!
Old 12-13-2014, 06:12 AM
  #312
flytmates
Anton, what size is the afterburner ring? 109mm?
yes, we will support the afterburner ring (made in Taiwan) for F-16 1/5 , the price is $ 95.-USD
Old 12-13-2014, 06:31 AM
  #313
pilot tw
Please check this picture, the afterburner ring is 5.3"
Old 12-13-2014, 06:57 AM
  #314
flytmates
Awesome!! Thanks Anton!!
Old 12-13-2014, 04:17 PM
  #315
RonTins
This is impressive Anton!! Keep up the R&D..
Old 12-13-2014, 05:03 PM
  #316
FenderBean
FenderBean's Avatar
Anton, what about all the other jets that use this same L bracket? My Avanti XXL uses them any thoughts other may give as well? thanks!
Old 12-13-2014, 05:21 PM
  #317
dubd
dubd's Avatar
The Avanti doesn't have slats and you won't be flying the F-14 at 200 mph.
Old 12-13-2014, 05:28 PM
  #318
FenderBean
FenderBean's Avatar
It has nothing to do with speed but force applied, you can put just a much force on something that does 180mph as 200mph.
Old 12-13-2014, 05:29 PM
  #319
pilot tw
only slat servos mount need change it, because the designed of slat is Different Direction with all servo linkage,
ID:	2054859   Click image for larger version
Old 12-13-2014, 05:34 PM
  #320
FenderBean
FenderBean's Avatar
Cool deal thanks for the info.
Old 12-13-2014, 07:42 PM
  #321
Pepperpete
Pepperpete's Avatar
And this is exactly why I won't be using a 300 until it's cleared by Anton to do so. Keep up the good work!
Old 12-15-2014, 01:38 PM
  #322
shoyt1
Anton,
Glad to see you found the problem. Quick question on adding a stronger servo mount material. If the force generated by the leading edge slat was enough to break the mount by replacing that with stronger material will that transfer enough load to the servo to cause the gears to strip? Is there a deeper problem happening here? the extra speed that likai was flying, the trajectory of the linkage? look forward to your thoughts.
Old 12-15-2014, 02:17 PM
  #323
dubd
dubd's Avatar
Does your Avanti have slats?
Old 12-21-2014, 07:55 AM
  #324
mhadjiky
mhadjiky's Avatar
I am interested for SM F16 1/5. I will follow this thread to get some info.
Old 12-22-2014, 07:44 AM
  #325
snobird
My Feedback: (36)
snobird's Avatar
Hey Guys, has anyone received their 1/5 size f16. One on order last July. .?
