Its Coming!!!! Skymaster 1/5 F-16 Arf Plus Pro
#602
Barry
#603
I need some tips... i am doing the setup of my F16...
I will use regular flaperon (instead of taileron)..
Slat i only get 21mm instead of the 25mm that the manual ask.. so i put 15mm 1st position and 21mm in the second.
Flaperon, if i put 75mm of flap i can't get aileron together (flaperon), i setup 25mm of flap 1st position, and 50mm in the second (both mix with slat)
Aileron.. manual ask 17mm each side.. (measure inside or outside?)
Elevator and rudder as manual.
Anybody can help me?
#604
Well as far as the leading edge flaps and the flapperons sounds like enough to me to get it in the air no problem... Ailerons are normally measured on the inside..
Can you post a picture of your pilot in the cockpit? I'm interested in a tailormade pilot but want to make sure the fit is good...
Brian
Brian
#609
Rex, your pilot post came at the right time as I'm looking for one. Perfect size and great price. Wish they offered it in a red uniform. Your F-16 went together fairly quick! Hope mine does as well.
#612
#616
GA
Are you using Taileron or standard elevator and aileron?
