Reload this Page >
Its Coming!!!! Skymaster 1/5 F-16 Arf Plus Pro
Reply
Old 10-09-2019, 10:11 AM
  #976
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by ARA-Jet View Post
Can someone please post the surface throws for each flight mode?
in the manual, for flaps, it says 100mm for Elevons. I dont think that is correct? Seems too much for lateral movement!
I don't have the SM jet anymore so I can't measure anything. I do remember I reduced the flap travel to about 1/2" on TO and Landing to help reduce the pitch sensitivity I was experienceing. I think I posted what my throws were somewhere on this or the other F-16 build thread. It may still be there.
I never had any issues with my LEF system. I could not tell if they made much difference or not.
My intermitent gear issues turned out to be a bad crimp on one of the wires to the Jetronics main gear air valve.
Gary
Viper1GJ is offline
Old 10-10-2019, 03:31 AM
  #977
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Spencer. I just told ARA via PM I will measure my settings and report back soon. Regarding the gear lock, what I did to keep it simple was Y lead the gear up and unlock but make the unlocking airline as short as it can be and lengthen the gear up airline. This creates a small delay between unlock and gear up and should allow normal operation. As Gary said the there is no issue with the LEF set up. In fact itís really solid and has a built in mechanical failsafe. I use LEF and flaperon for TO and landing.
Cheers
Levi
Levi Wags is offline
Old 10-16-2019, 12:28 AM
  #978
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Guys sorry for delay, here are my settings:
Rudder- 25mm each way (measured bottom of fin)
Aileron- 20mm up, 15mm down (measured wingtip end)
LEF- as much as you can on landing, half that on TO
Flaperon- 20mm (measured next to fuse) for landing, half that for TO
Elevator- 60mm up
CG 260 from wing LE next to fuse empty LG down
IGyro SRS about 35% on everything dampening mode only
My bird is heavy at 27kg dry but flies awesome. My settings are not necessarily correct but after experimenting with different settings they work best for me.
Cheers
Levi
Old 10-16-2019, 12:42 AM
  #979
lavi rider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1/5
27 kg dry ???????
the Scale jets 1/5 weighs 20kg dry ..
the BVM PNP about 21.5-22.5 KG
Why is your Viper 27KG? Any special features you added ?
lavi rider is offline
Old 10-16-2019, 02:22 AM
  #980
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lavi I do have a lot of gear in there. P300 is heavy, anamatronic pilot, lights, burner ring, smoke tanks, Jetcat E10 smoke pump, Itraps for fuel and smoke, Powerbox batteries etc. Plus the SM F16 itself is much heavier than BVM, landing gear is bigger and heavier.
Originally Posted by lavi rider View Post
27 kg dry ???????
Old 10-16-2019, 02:51 AM
  #981
lavi rider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1/5
we got all that in our 1/5th PNPís . Jet cat 300ís etc still 22.5 kg ..
same size wheels these are 1/5 th all dimensions are about the same with slight deviations .. we talk about 5kg difference itís a lot 25% !
And compared to the one from scale jets again 1:5 itís 33% !
Wow !
Old 10-16-2019, 03:18 AM
  #982
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes but the BVM LG is very skinny and basic looking. SM much more robust and scale. Thereís a scale jets F16 here thatís 26 dry too. Depends on set up I guess.
Wow !
Old 10-16-2019, 03:20 AM
  #983
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Also the SM is about 5% bigger than scale jets, even though they say both are 1/5. I’ve had them both in my workshop at once. I was painting both together. I’ll try to dig up some comparison photos I took.
Old 10-16-2019, 03:25 AM
  #984
lavi rider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1/5
I see ,
all the ones I judged at the Jwm where loaded with all scale options , scale canopy , some had drouge chute on , lights , extremely detailed wheel bays , cockpits etc . All up weight was under 20kg each and there where 6 F-16 from different competitors .
Good oof luck with yours
Old 10-16-2019, 06:28 AM
  #985
Craig B.
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Levi,
do do you think a 250 or 260 would fly her well or do you need the extra thrust?
Craig B. is offline
Old 10-16-2019, 11:10 AM
  #986
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool Lavi. Yes Iíve seen some scaled up JWM 16s come out light. I think thereís even a large SM one competing but LG looks modified. If you find out the secret to weight saving let me know 😂. I always try to build light but this ones a porker.
I see ,
Old 10-16-2019, 11:13 AM
  #987
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Craig a 250-260 would be fine mate. I could strip out smoke system and switch to a 260 and save lots of weight and have a machine thatís easier to land. Itís fun going vertical with the 300 though.
Originally Posted by Craig B. View Post
Hey Levi,
Old 10-16-2019, 11:33 AM
  #988
lavi rider
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default 1/5
i personally know Marjin ( producer of the Scale jet F-16) and I can tell you right there . His F-16 including his landing gear ( 100% scale accuracy) built following his instructions come out UNDER 20Kg ...
wow ..
including functioning canopy , dive brake, lighting , flaperons , Le flap, stabilizer, rudder, smoke , AFB ring . And it flies with a 180 size turbine .
Old 10-16-2019, 12:42 PM
  #989
Levi Wags
Levi Wags's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mate Iím not disagreeing with you. Iíve had both jets in front of me at once and Iíve painted both sets of gear so I have a better comparison than most. The SM is what it is and Iím happy with it. Just posting my settings to help others so Iím not sure how this has turned into a pissing contest.
wow ..
Old 10-16-2019, 03:03 PM
  #990
ARA-Jet
My Feedback: (8)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Throws
Thank you for posting your settings.
Anyone flying with elevon? Can you please post how much throws you are using for elevon and elevator?
ARA-Jet is offline
Old 10-17-2019, 06:08 PM
  #991
Spencer K
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your setup Levi.
would anyone mind posting some pics of the gear door mounting locations/template/proper geometry? Nothing is shown in the manual version I have so perhaps someone has it figured out.
also what psi seems to be best in the struts/ tires?
Lastly my nw steering is pretty stiff and there is some slop. is this normal?
Spencer K is offline
