DYNAMO aerobatic trainer / advanced fun model build thread
#76
ON, CANADA
A friend cnc'd some new carbon servo plates for my plane. We came up with this method for the elevators. I am using MKS 6625HV wing servos with three mounting lugs. We had to flip the servo output over to the inboard side of the bay as I did not want to notch the inboard rib for the bottom servo lug clearance. This rib has the elevator tube running through it. When I get them mounted I will post pictures. Will also change mounting bolts to button heads.
#77
I just bought mine from a guy who ran out of time to start the kit......anyone find the wood a little cheap? I'm planning on replacing some of the formers and the engine former with real aircraft grade ply. Just seems real flimsy.
DC
DC
#80
ON, CANADA
Looks great Stephane. Mine is still on the bench so far my only complaint has been the limited space for mounting servos even the 8411's are to big. It will most likely not see flight until 2016.
Not a popular model in North America. Have you had any problems or have you need to modify anything?
#86
ON, CANADA
#89
#90
ON, CANADA
Looks great Stephane! Mine is still not done, this winter for sure. Have you any experience with the Scirocco. Been thinking of ordering one but the shipping to Canada is crazy$.
#93
