Large Skymaster F4 install pics
Reply
Old 11-27-2013, 01:24 PM
luv2flyrc
luv2flyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Large Skymaster F4 install pics
I have searched all the posts regarding the large F4 from Skymaster but, there are very few installation pics on RCU. I'm in the process of assembling one at the moment and hoping that some members can share their install pics or point me to some good ones.
I have my own ideas eg. all turbine equipment on the tray above the main fuel tank, radio equipment on a tray on the floor behind the nose gear but, would like to see how others have it laid out as well.
Particularly interested in how you've rigged the small nose gear door to retract. Skymaster suggests cabling it to the nose gear, I don't like that option. I'm sure someone's done it better.
TIA
Mike
luv2flyrc is offline
Old 11-27-2013, 02:51 PM
ravill
ravill's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great airplane. I'll post some pics for you when I get to it.
ravill is offline
Old 11-27-2013, 02:58 PM
luv2flyrc
luv2flyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice scheme! Thanks, would appreciate it!
Mike
Old 11-27-2013, 03:00 PM
Flynstuff
Flynstuff's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll post some when get back to the office.
Flynstuff is offline
Old 11-27-2013, 04:57 PM
Flynstuff
Flynstuff's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here yah go Mike
https://www.rcturbinejets.com/instal...-photos-1.html
Old 11-27-2013, 05:17 PM
luv2flyrc
luv2flyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Jeff,
Those are some great shots, gives me some new ideas
Mike
Old 05-01-2014, 06:52 AM
luv2flyrc
luv2flyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Almost done rigging the Phantom and I've saved the best for last; rigging the gear doors
Doors came hinged but, I didn't order the install kit as i figured I'd use better quality after market stuff. I'm having a challenge with the air cylinders on the small inner main gear doors. I'm trying to use Robart 168's there and there's not enough room to mount them as the wheel is so close to the gear door opening the cylinder won't fit in between. The Skymaster OEM cylinders must have a much small diameter than 3/8"?
Also, even if I was able to get the cylinder in there, the geometry looks to be so poor that the gear door would surely pull open during flight. Anyone experiencing this problem with the F4 gear doors?
If anyone has some close up pics of their gear door install, I would much appreciate it. I'd also like to see what you have done to attach the small nose gear door to the nose gear strut.
Mike
Old 05-01-2014, 07:12 AM
f106jax
f106jax's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike,
I'm using the SM supplied cylinders on the inner main gear doors. They are attached to the former at the rear of the door opening. I've never experienced an issue with them opening in flight.
As for the small nose door, I just let the air stream push it closed...same as the KingCat nose door. It's worked fine for over 100 flights.
Wishing you the best with your Rhino! You'll love flying it.
f106jax is online now
Old 05-01-2014, 07:29 AM
yeahbaby
yeahbaby's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mike regarding the small nose gear door, I simply hinged it with a dubro flat hinge and allowed the air stream to close it in flight. Think kingcat nose gear door. Works great, stays closed in flight and opens when the nose gear comes down. You simply put a piece of lite ply / balsa whatever you desire to create a bumper so it doesn't jam on the nose gear strut.
Not scale perhaps but functional, reliable and executes the KISS principle wonderfully.
The small outer gear door for the mains is a PITA but nothing a small piece of wire and simple geometry can't fix. Years ago Dave Presta actually installed a small servo in the wheel well. The main gear inner wheel doors are also challenging to get the geometry / air cylinder stroke in the correct position but once again trial and error. I supplemented the air cylinder geometry with small rare earth magnets on the inside to assist in keeping the doors closed in flight. Worked great
Can't argue when the stuff is simple / reliable / functional and provides easy maintenance.
sorry no install pix any longer but here's some motivation
Name:	F4 low and mean.jpg
ID:	1991687   Click image for larger version
ID:	1991688   Click image for larger version
Name:	SVF 11 June 014.jpg
yeahbaby is offline
Old 05-01-2014, 10:15 AM
smaze17
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow Rav that is one Be-uteiful Rhino. Do you still have it?
smaze17 is offline
Old 05-01-2014, 11:00 AM
luv2flyrc
luv2flyrc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ok, thanks for the feedback guys, I'll continue to "play" with the geometry tonight. I like the idea of just letting the airstream push the nose door up too. I may see if I can hang a magnet there somehow to keep it closed during transport otherwise, I know I'll knock it off
Mike
Old 05-01-2014, 12:36 PM
yeahbaby
yeahbaby's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LoL. A piece of tape works. Just be sure to make it obvious there's tape down there. Ask me how I know. LoL
best flying phantom out there next to BVs battle tank!
yeahbaby is offline
Reply
Display Modes
