18MZ Audio File transfer
My Feedback: (90)
Hello all! My question concerns moving a model program from one 18mz to another 18mz.
On the original setup I built sound files for things such as gear and flap position. "Gear UP" ect...
When I created the sounds I saved them to the SD card as well as the transmitter.
I also copied the model from the transmitter, to the SD card.
Powered down, removed the SD card, installed into the other TX and powered up.
Selected the model from the SD card.
My issue is that none of the sound files work.
I looked at the sound menu and when I select a sound such as "Gear UP" it displays "file not found".
Is is it possible to move these audio files? I'm also still looking for a hot Australian girl to record audio files for me. Bad thing is, I'm in Oklahoma!
My Feedback: (90)
Got some very good help via PM so I thought I should repost the information here below.
"Go into the LINKAGE menuTap on SOUND
Tap on FILE next to a given switch
You will see transmitter and disk drive icons
Select the disk drive icon
Select a sound
Copy it to the 18MZ
Now you can use it on the 18MZ.
Unlike the 14MZ the 18MZ stores sound and picture files internally. You can take the SD card out and still have both. Unlike the 14MZ where if you took the CF card out you would no longer have sounds."
Select a sound
Copy it to the 18MZ
