Behotec 220 mount
depends which bypass you intend to use. If you are fitting the 220 in a Jetcat 200/AMT Olympus bypass then you might find the cast mounting T's are not long enough. If it's the small engine bypass you have then the 160-180 straps should work fine.
Jason
Jason
I will be really interested to hear how the UB performs compared to the 200SX. I also have a UB with a 200SX which I'll fly soon and a Airworld F-100 with a 200SX so if there is an improvement to be had I might think about doing it.
Jason
