JetCat Turbines on Premium Diesel (Shell V Power and BP Ultimate)
My Feedback: (76)
[QUOTE=Dave Wilshere;11723045]
That doesn't make sense, perhaps on a p-80 sized engine where the thrust is small, but on a large p-200 or larger you will see a difference, I see power improvements of 1-2 lbs on my 180 sized engines both KINGTECH an Behotec, I'm sure this will equate to a 2-3 lb on a jet cat p-240.
Diesel will generally have a rougher start and slightly worse acceleration it will HOWEVER give you 3-5% boost in power, on My Behotec 180 GOLD, I get 42 and 3 oz of thrust on Diesel and 40 lbs 8 oz with K1 Kero.
You won't see a power increase on JetCat, when I asked them they said no difference, although Diesel has a higher Caloric value, its not enough to show more power.
Dw
Dw
Why do they gain power? If diesel holds more energy it would result inte less fuel needing to go in the engine. If the pump are kept at the same PW of course power will increase, but so will RPM.
I do not know how clever Xicoy are compared to Jetcat. I can however imagine if just switching fuel in the bench just reading the scale for thrust the engine would run at a higher rpm before ECU have adopted it self.
What do you guys think?
We are flying our Frank-Turbines (www.frankturbine.com) with all sorts of fuel (Diesel or Jet A1 or a Mix of them) what we could get. Also Mr. Frank has made a lot of Testruns with DIesel or Jet A1. But what we found out is that the Thrust of the Turbines is about 0,4 KG less than with Jet A1. We didn`t find out that there is more Power with Diesel.
Karsten
Karsten
#31
I just started out running diesel in my Cheetah with 2.5% two stroke racing oil. It is just so easy to get. I agree that it puts out more smoke on shutdown. I do not know if the different brands available here in the states run differently. I am using two different stations locally. I did not realize this was something new as I am new to jets with only 70 flights on the Cheetah. I like that diesel doesn't really smell bad. I know from work that Jet A is hands down the worst smelling stuff to get on hands or clothes. I thought owning jets would mean a stinky garage, van, etc. but with diesel it has not. I think it is great that JetCat will allow it. I look forward to my 25 hour service to find out if diesel is harder on the turbines or not.
#32
My Feedback: (10)
I have run diesel in a P-60 for a long time. Maybe 2 years or more. It seems to have had no deleterious long term effects. It is SN 22 or something and I have had 1200+ flights and it has been in for work twice, new bearings only. Pretty reliable.
I will say however it runs_much_rougher on diesel (sometimes so rough on transition you think it might quit). On K-1 it is smooth as silk.
I would look at this decision (kerosene vs diesel) less as a long term reliability question and more on the operating stability of each turbine individually. Just my opinion.
#33
CA
Do we know if there is any greater chance to flameout with diesel? or is the probability about the same as that of kero. I supposed most flameouts are due to plumbing and filters more than fuel type?
#34
Hi Dave,
I'm using Diesel in my Kingtech and apart from some popping during the fuel ramp phase and some smoke after shutdown it's fine. Best thing is that there is almost NO smell. If Kero leaks or gets on your hands one can really smell it! You can rest assured that the diesel (the type we get in Hong Kong anyway) does not smell.
cheers,
Leon
cheers,
Leon
#35
I use Diesel in my Kingtech...and the factory rep tells me that it produces slightly more power than Kero...no added risk of flameout...most of them are due plumbing/blockage/air bubble issues.
#36
It sort of shows you the true face of your engine. If it runs well on diesel it's a good design with proper evaporation etc. If it runs rough on diesel things can be made better which would benefit Jet A1 use too.
#37
My Feedback: (76)
the roughness can be smoothed out with tweeks to the ECU, in general, you need less diesel than kero to get your turbine started.
But for the most part yes, Diesel will be a little rougher than kero in acceleration and start up, and certain turbines like Behotec / Kingtech and YES Even Large Jet Cats will produce 3-4% more thrust at the same RPM. Just tested my
JetCat 240: 56.7 lbs K1 Kerosene
Jetcat 240: 58.5 lbs Shell V-power Diesel
40 degrees Fahrenheit outside temp, 300 ft sea level
#38
Hey did you have to change ECU settings to get your jetcat to run on Diesel?
With the Kingtech you certainly have to.
Paul.
#39
My Feedback: (76)
I haven't had time to change jetcat ESC settings, however, on both Behotec and Kingtech the 1 common is LOWER PUMP START voltage and Ramp Up voltage.
2ndly Increase glow power if possible for the ignitor. I will start tweeking the jetcat esc this weekend.
All thurst was measured using Medusa Tech e-reader with the thrust plate. turbine was on a ball bearing rail mounted wood block.
#40
#41
On my Cheetah I ended up (following the directions) lowering the Pump PW Ign. K value from the default 031 value to 015. This is the start sequence fuel used to bring the turbine up to temperature for the pre heat cycle to start. So it is much lower than expected with diesel. Note that it started just fine at 031. Below 015 the starts got longer and below 013 it would not start.
#43
My Feedback: (76)
Full power RPM was the same, 110k for the 240 this is set by the ESC, it doesn't really care what fuel it uses as long as it can get to the MAX RPM that is defined in the ESC, it can be OVER CLOCKED/ Err Over Thurst to 112K RPM at which point the diesel should put about 60 lbs or so.
#44
#45
My Feedback: (76)
I haven't messed with that, I'm using the V6 gsu, I talked with Bob regarding this and he said as long as the pump voltage doesn't go over 6.5 volts it the learning will be fine.
My max on diesel was the same as kero 6.03 volts.
#47
