Reload this Page >
Skymaster F14 Assembly
Old 08-20-2014, 03:31 AM
  #101
WimB
WimB's Avatar
Fred,
looks very nice, I love the A10 as well.........next on my wish-list....
Wim
Old 08-23-2014, 08:54 AM
  #102
Alex48
Alex48's Avatar
The Little Jet Company's New scale product line starting with these removable 1/7.5 scale Pitot, AoA, AIC and TAT probes. You get six probes in a set all pre painted just cut the hole, glue the backing plate on and your good to go. We have nearly sold out of kits with only 8 remaining! Email us for more information. [email protected]
Plenty of progress on the F14 as I'm trying to get it ready for September I'll update the thread in the next few days.
_DSC6633
Old 08-23-2014, 09:06 AM
  #103
smaze17
My Feedback: (60)
Wow Alex really slick. Your stuff is amazing.
S
Old 08-24-2014, 09:45 AM
  #104
Alex48
Alex48's Avatar
Old 08-25-2014, 02:25 AM
  #105
Alex48
Alex48's Avatar
Rudder servos have all been installed, there were no mounts in the rudders so I had to make my own, while the hysol was drying I started weathering the gear. I just need to add a few hand painted details and of course some decals and they will be ready to go back in.
_DSC6619
Old 08-25-2014, 02:50 AM
  #106
Colin Allen
Colin Allen's Avatar
No mounts in the rudders? I haven't received my kit yet, so curious what was SM's intent here. Was your kit faulty or did they mean it to be that way?
Old 08-25-2014, 04:27 AM
  #107
WimB
WimB's Avatar
Colin,
I can only guess that alex is referring to the rudder horns. The rudder servo's are mounted in one of the rudder formers.
Wim
Old 08-25-2014, 04:44 AM
  #108
FenderBean
FenderBean's Avatar
Alex what did you use to cut the antenna mount areas out?
Old 08-25-2014, 05:36 AM
  #109
Alex48
Alex48's Avatar
Sorry guys I didn't articulate the issue very well...
When I opened up the rudder to see how to connect the rudder to the servo, I found just an empty space. I made some carbon plates and built a bit of internal structure then injected loads of hysol to bond it all together. I'm not sure if this was left to the builder or not but the instructions show you just cut a slot for a ball end horn and screw it in from the bottom of the rudder. It would be nice if this had been done at the factory perhaps mine was an early one, I'd be interested to see what other people got. Here is a link to the instructions so you can see what I mean.
http://www.skymasterjet.com/f14v6.pdf
_DSC6606
Old 08-25-2014, 05:38 AM
  #110
Alex48
Alex48's Avatar
Hi Fender, I use a tool the model car guys use to cut holes in the plastic bodywork, I forget the exact name, sorry.
Old 08-25-2014, 05:48 AM
  #111
WimB
WimB's Avatar
Alex,
I had the same thing, no balsa or at least not enough to bond the two carbon fibre horns to... I opened the bottom of the rudder some to bond the horns with glue. the horns are angled as well, so I can run the actuator rod in a straight line.
here's two pics of my rudder base. I will add a carbon base to the bottom of the rudder for stiffness later.
I know, looks a bit messy, but this was before cleanup. I also tried to mount the horns to the outside as much as possible, giving me good leverage on the rudder.
Name:	DSC_0030 (Large).JPG
ID:	2025674   Click image for larger version
Name:	DSC_0031 (Large).JPG
Old 08-25-2014, 07:14 AM
  #112
mick15
mick15's Avatar
My approach was much simpler I just drilled a 6mm hole into the balsa sunk in an aluminium rod which was drilled and tapped 3mm for the ball joint.
m
Old 08-25-2014, 07:28 AM
  #113
Craig B.
That would be a body reamer Alex. Nice work on the rudder horn....that should be solid.
Old 08-25-2014, 06:47 PM
  #114
Chris Nicastro
Chris Nicastro's Avatar
I have a couple photos you can use to make data plate decals for the gear if you can use them. These are large files over 5 megs of the gear in close detail frm the F-14D in Hawaii. Let me know and I can email them to you rather than post them here.
Old 08-25-2014, 10:02 PM
  #115
invertmast
My Feedback: (23)
invertmast's Avatar
Chris,
If possible, i would love to get a copy of those photos.
Thomas
Old 08-25-2014, 10:05 PM
  #116
Chris Nicastro
Sure, PM me your email and I'll send them directly
Old 08-25-2014, 10:52 PM
  #117
Alex48
Alex48's Avatar
Hi Chris, Thanks for the offer, I'd love a set of those photos, PM sent...
Many thanks,
Alex
Old 08-26-2014, 08:45 AM
  #118
Chris Nicastro
No worries, I sent several emails late last night so you guys let me know if the big files came thru ok.
I take photos of these details all the time and its nice to have them for reference.
Old 08-26-2014, 09:16 AM
  #119
FenderBean
FenderBean's Avatar
May seem like a dumb thing but I don't suppose u can post a pick of this tool or link.
Old 08-27-2014, 02:45 AM
  #120
Alex48
Alex48's Avatar
Here is a link to what they look like, I find them great for cutting holes in composites, it needs a little finishing afterwards due to the slight taper.
http://www.ebay.co.uk/itm/like/11140...13=80&ff14=108
Old 08-27-2014, 03:16 AM
  #121
FenderBean
FenderBean's Avatar
Thanks, I understand now I thought it was something different! New tool to add to the box! Alex I will send you an email in a couple of days with the address to send that kit. I should be leaving here in about 3 weeks, my f-14 shout be ready for pain soon as well. Im hoping to make it home to get the paint colors I need to send them for the correct colors on my scheme. Trying to be very specific! Thanks for the info
Old 08-27-2014, 06:17 AM
  #122
Alex48
Alex48's Avatar
No worries, If possible send Skymaster physical paint chips of your required colours. They will match that very accurately, its very hit and miss via email as all sorts of things get distorted with colour via a monitor. My client who ordered the F14 was also very specific and they turned out an exact match having sent the chips.
Looking forward to seeing yours come together.
Cheers, Alex
Old 09-05-2014, 12:02 AM
  #123
Alex48
Alex48's Avatar
Thanks to everyone who ordered a probe kit. Here is a picture of what you will be receiving in the post. Progress has been really good on the model and it should be ready to do the ground testing next week.
_DSC6640
Old 09-05-2014, 12:31 AM
  #124
WimB
WimB's Avatar
Alex,
looking forward to my kit, looks super!!!
I suppose the box can be used to store the probes?
any progress on the rest of the details?
Wim
Old 09-05-2014, 12:49 AM
  #125
FenderBean
FenderBean's Avatar
Alex I sent you an email with my address to get mine shipped. Thanks again!
Oh meant to ask does the real f-14 have the base areas like your set? I never looked to see if the base of the antennas matches the antenna color itself.
