Stripping a Eurosport
Have got a Eurosport fuselage that I'd like to strip the multiple layers of paint off. Is there a proven chemical paint stripper that will do the job? I do have NitroMors but seems from various forums I've found it would probably damage the gel coat or worse. Any advice appreciated. Dom
My Feedback: (24)
I stripped the paint off of ours (2 layers, original and one repaint) using Citristrip. It worked pretty well in that it got most of the paint off. It did get down to the weave in a couple of places and also exposed some voids in the original paint/gelcoat. I wound up doing a bit of filling/sanding to fix that, and if I had to do it again, I might just have stuck with sanding the old paint off...
Of course if I did that, I'd probably be complaining about the work of sanding and that next time I'd use a stripper...
BTW, our Euro was 6 years old when we stripped and repainted it, and that was 2 years ago...
Bob
My Feedback: (32)
I've stripped a few Skymaster planes using CitriStrip. Took the paint right off down to the gel coat with no sanding needed. Your results may vary depending on the type of paint you are stripping.
Kirk
Kirk
Many thanks all for the replies. Rare to have concensus on an answer to a question on RCU isn't it! How refreshing. I'll get hold of some CitriStrip and crack on. Thanks again.
My Feedback: (67)
Dom, some strippers are more aggressive than others. Just read the labels, a few I looked at said "could be" harmful to fiberglass. Citristrip isn't as aggressive, and while it does take longer as a result, it doesn't hurt the surface. I would imagine you should be able to find a UK equivalent.
My Feedback: (44)
IL
Hi there,
I just stripped and finished mine with the natural citric stripper , also for removing the four layers I used # 0000 , 0001 still wool about four to five bags.
here are some pictures.
Left the NitroMors on for up 45 minutes and it didn't even dent it! Yes, may well try thinners. Citristrip not available on Amazon.co.uk. Nice paint job Spaceman...something to aspire to.
My Feedback: (67)
http://youtu.be/CdrK_quKaVw
http://youtu.be/e5f9wH9_5m0
My Feedback: (8)
TX
Several years ago, I stripped a Composite ARF MiG 15 that had several layers of camo paint on it successfully without damaging the fiberglass. I went to an automotive paint store, and they recommended Klean-Strip Fiberglass Paint Remover (used on Corvettes by body shops to remove old paint). It removes paint, acrylic, polyurethane, lacquer, and enamel from fiberglass with no damage. You do need to wear rubber gloves as it is caustic and can burn exposed skin, but it sure worked for me and I was really pleased with the result. Be sure to wash the surface with soapy water after stripping to neutralize any residual stripper before repainting.
Good luck with your project.
Regards,
Regards,
