BIG A-5 Vigilante build
Reply
Old 11-26-2018, 07:04 PM
  #526
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
here they are on the plane. I don't know if they are Jet A proof but I am not going to seal them. If they fade or get ruined I will print and cut another set. They were cheap and quick to make.
Left intake
jofunk is offline
Old 12-02-2018, 09:46 PM
  #527
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I propped up the fuse on the front spar. It is 6" in front of the CG. The fuse. tipped very nose heavy. I think that is good at this point since there are quite a few things that will be behind the CG.
Hopefully I can balance the plane by shifting things in the plane to spare adding lead. But we will see.
I bolted the dummy turkey feathers on the back
I also bolted thee nose on and installed the landing gear.
I made a paper template of the back of the fuse. I will start stacking some blocks of urethane foam to create the fairings on the back of the fuse.
jofunk is offline
Old 12-02-2018, 10:09 PM
  #528
LGM Graphix
My Feedback: (22)
LGM Graphix's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nice to see this one getting so close! Great work. Look forward to pictures of the complete airplane all together.
LGM Graphix is offline
Old 12-03-2018, 08:26 AM
  #529
turbofixer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looking good Joe...Cant wait to see it all together on its gear
Scott
turbofixer is offline
Old 12-04-2018, 01:03 AM
  #530
doubledcom
My Feedback: (49)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome job Joe!!!!
doubledcom is offline
Old 12-05-2018, 09:38 PM
  #531
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks all for the words of encouragement... Here is a picture of the plane all put together at our club meeting tonight. I was pleased to learn the plane assembled with the engine installed in the tail it balances very close to on the money. It sits on the gear nice with the CG in front of the mains very close to where it should be. Everything left to go in the plane will install through the top hatch on or close to the CG. The second picture is of Vladimir next to the plane. He is the man to credit for making the beautiful landing gear for the Vigilante.
jofunk is offline
Old 12-06-2018, 09:39 AM
  #532
turbofixer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Outstanding..Beautiful looking jet!!
Old 12-06-2018, 09:41 AM
  #533
turbofixer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow
Old 12-06-2018, 05:00 PM
  #534
spaceman 01
My Feedback: (44)
spaceman 01's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice work Joe and Vladimir I canít wait to see a flight let me know when youíre going see you Nick
spaceman 01 is offline
Old 12-16-2018, 10:00 PM
  #535
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a plumbing question. I was thinking about using two 100oz. Dubro tanks for fuel. There are two ways to plumb them. The first would be to have two pick up lines teed to the pump. The second would have one pick up line and the other tank feeding the pick up tank. What has been peoples experience and what are the pros and cons.
jofunk is offline
Old 12-17-2018, 08:23 AM
  #536
jescardin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Congrats Joe for the Vigilante!.
Regarding your question, you must know parallel plumbing the fuel tanks has a greater risk of feeding air to the turbine and instantly killing it. On the other hand, series plumbing them reduces this risk although you may have troubles with weight distribution as fuel is used.
If it is the case, best solution should parallel connect both main tanks to a smaller feeder or UAT one which will connect to the turbine pump.
I wish you the greatest success when you go for maidening your Vigilante!.
Best Regards.
jescardin is offline
Old 12-19-2018, 05:49 PM
  #537
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is what two 100oz. tanks look like in the plane. They will probably be installed flat and not on edge. Everything else that needs to go in the plane will be above the fuel tanks. I think the best way to plumb them together will be in series. The weight imbalance side to side shouldn't be an issue with the tanks only a few inches off the center line.
jofunk is offline
Old 12-19-2018, 06:42 PM
  #538
redtail
My Feedback: (15)
redtail's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Jofunk - what a beautiful build. What are you using to tint the West Systems. What a great idea if that is what you are doing. Chic
redtail is offline
Old 12-23-2018, 08:15 PM
  #539
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Redtail. The tint in earlier posts were black and red. It is tint that is available at any store that sells resins and casting material. I made a retention frame to hold the tanks in place and to hopefully contain a spill if it happens. The swail along the back is so I can get my hand and arm into the rear of the fuse to work.
jofunk is offline
Old 01-04-2019, 07:30 PM
  #540
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here is the fuel tank hold down tray that will take the ECU, fuel pump, turbine battery, receiver, and receiver battery. The aluminum angles will get screwed into the sides. The bolts coming up will stay a little ling in case something needs to be bolted on them. The tray will get an air dam on the front to keep everything on the tray out of the air stream.
Here is a pic from the engine compartment looking forward.
I forgot to frame out a hatch for the back seater. I outlined it with some charting tape and will burn some rivets around it. It will then get another mist of paint.
jofunk is offline
Old 01-25-2019, 05:55 PM
  #541
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The GFS maple syrup is crazy thick, very heavy duty. I had the vent and pick up lines friction fitted through the wall of the bottle, no fittings. The neoprene with Viton hoses in the tank were like brand new after many years, so I reused them in the new tank. I cut the bottle open to get a good look inside. no garbage or growth, just discolored.
My Boomerang Xl tank needed an update. It finally started leaking under the cap after 13 years.
The wires will get secured in the rear
I opened a hole in the floor to run the servo wires under the floor
I burned some rivets around the back hatch
jofunk is offline
Old 01-29-2019, 08:37 PM
  #542
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put more rivets on the rear canopy and located the window
The rear canopy window will be aluminum tape. I just stuck one on there temporarily. It needs to be painted again above the blue tape.
jofunk is offline
Old 02-03-2019, 02:41 PM
  #543
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My friend Sebastian talked me into getting a K 210 for this. I think it would fly on a smaller engine but we will see.
A little steel wool for the paint to stick
I masked off and repainted the rear seat hatch area
jofunk is offline
Old 02-04-2019, 08:59 AM
  #544
turbofixer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Looks nice Joe
Old 02-06-2019, 06:59 AM
  #545
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks TF. The K 210 fits in the same holes as the K 170. It should be plenty of power.
jofunk is offline
Old 02-10-2019, 02:16 PM
  #546
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The RJ 45 locking tab is broken of on my cable. I will need to make another and a bit longer
here is the jack and pin layout for the cable
here is some rough layout of where things can go on the tray.
The tray got an air dam to protect the components
someone is using the landing gear bay as a Hot Wheels monster truck garage
jofunk is offline
Old 02-10-2019, 08:51 PM
  #547
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There will be no brass tubes in the tanks. All the lines will be friction fit through the walls of the tanks. The bung is just an access port.
this is everything pushed through the drilled holes. the vent lines are expanded with a segment of plastic tubing.Once pulled back through its very difficult to pull the vent lines out of the tanks.
The clunk lines are pushed back in with the length adjusted. One clunk line couples to one vent and they are plumbed in series.
jofunk is offline
Old 02-10-2019, 09:29 PM
  #548
jofunk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Swap the lines around and the pump can draw from the left or right tank. Thought exercise. If usually flying a left hand pattern (left hand bank) which tank is better for the pump to draw from? Or is there no big difference.
jofunk is offline
Old 02-11-2019, 01:27 PM
  #549
turbofixer
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you run the tanks in series left or right wont matter.As long as the clunk works..You could make the right tank the feed for left pattern and the fuel will sit closer to the centerline in turns..
Old 02-11-2019, 03:33 PM
  #550
LGM Graphix
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I could be wrong but I think your friction fit lines will be a big mistake. Once the oily fuel and suction from the pump are there I think they will leak. Not only that, I suspect the thin plastic wall of the tank will cut into the lines in short order. Brass tubes through a rubber stopper or thread in fittings glued into a tank are tried and true methods for years. If it could be as simple as friction fit through a tank I'd suspect that would be the norm already.
