Reload this Page >
Aurora Sport Jet from Q Composites
Old 11-02-2014, 06:31 AM
  #51
satdave
satdave's Avatar
Can anyone give me the dimension of the storage "case". I have to pick mine up and hope it fits in my vehicle.
Old 11-02-2014, 09:54 AM
  #52
smitty9969
My Feedback: (7)
1Pkg – 40Kg
273x56x60 (cm)
Old 11-02-2014, 11:29 AM
  #53
satdave
satdave's Avatar
Thanks Smitty,
Mine is the Breitling without stars...
DC
Old 11-02-2014, 05:07 PM
  #54
David Jackson
My Feedback: (15)
Thanks Smitty,
DC
Satdave, you will totally enjoy the way this plane flies. Got 6 flights on mine, and it is a great model to fly from a short field.
Old 11-02-2014, 07:55 PM
  #55
smitty9969
My Feedback: (7)
Thanks Smitty,
DC
Welcome to the Aurora family.
You should have her in a couple days.
Everyone loves the way she flies. I'm sure your going to enjoy her flight characteristics.
Old 11-03-2014, 07:36 AM
  #56
satdave
satdave's Avatar
Smitty,
Do you have any details regarding the shipment? Did it leave yet? You could pm me the details.
Old 11-03-2014, 08:49 AM
  #57
Speedf16
My Feedback: (16)
Help
1. Cg location
2. Throws of all surfaces
3.pics of air tanks location, batteries
4, wing size bolts to secure , wing to fuselage , mm?
5 . Thanks n safe flying
Old 11-03-2014, 08:59 AM
  #58
David Jackson
My Feedback: (15)
Originally Posted by Speedf16
Help
1. Cg location
See post #294 in the Aurora Project Announced thread here on RC Universe
Old 11-03-2014, 10:56 AM
  #59
EDFCrazy
Help
1. Cg location
CofG 250mm back to start
Throws
20mm aileron
25mm elev
max rudder
80deg flap
My airtanks are located under the tank tray. The original wing bolts are 4mm and are tightened through the wheel bay. I changed mine to 6mm threaded bar, then tightened with a thumb nut from inside the plane. My ECU battery 4200mah 9v life and two 2500mah 6v 123's are placed in the nose.
Old 11-03-2014, 08:04 PM
  #60
smitty9969
My Feedback: (7)
Smitty,
PM sent
Old 11-15-2014, 05:58 PM
  #61
satdave
satdave's Avatar
With a little grief at customs I received mine yesterday. Very nice plane.
Old 11-15-2014, 07:42 PM
  #62
smitty9969
My Feedback: (7)
Thank Goodness for the hard case..
Old 11-15-2014, 11:30 PM
  #63
David Jackson
My Feedback: (15)
Glad to hear you have received your Aurora. .
Old 11-16-2014, 08:27 AM
  #64
EDFCrazy
What color did you get?
Old 11-16-2014, 08:37 AM
  #65
EDFCrazy
Here are two videos i found of this amazing jet from jetpower 2014.
https://www.youtube.com/watch?v=odziNehUbus
https://www.youtube.com/watch?v=LyHE8y1XZBY
Old 11-16-2014, 09:49 AM
  #66
satdave
satdave's Avatar
Smitty,
I guess that might of been some of the hold up in Chicago......... Your right if that was a wooden crate would have been an entirely different story.
Old 11-16-2014, 10:02 AM
  #67
satdave
satdave's Avatar
Default Aurora
I went with Breitling, no stars. P-180 and Power Box. My wife is happy that it made it home without damage. If she only knew how much I spent...............
ID:	2047833   Click image for larger version
ID:	2047834   Click image for larger version
Old 11-16-2014, 10:13 AM
  #68
EDFCrazy
Very nice, that was one of the schemes i was keen for, without the stars too. nice to see a pic of what it would have looked like.
  #69
3dean
did anyone video the vector thrust version
Old 11-16-2014, 10:52 AM
  #70
ModellbauUK
ModellbauUK's Avatar
The Breitling scheme was our first demonstration model and is still my favourite. Now I have the carbon one back from 2014 demonstration I'll be flying it as my sports model. The promotion of the Aurora is all done now and it's great to see the continuing success of the model.
Looking forward to moving on to the Swift which I fully believe will be an even greater success as it will be coming from a proven pedigree which is QComposites.
Ian
Old 11-16-2014, 07:56 PM
  #71
smitty9969
My Feedback: (7)
Smitty,
There is always a debate on whether the hard case is necessary. I guess this proves our decision..
Always good to see a spouse happily involved in this hobby..
I welcome her also to the Aurora family.
Old 11-22-2014, 06:36 AM
  #72
satdave
satdave's Avatar
Smitty,
Any input on a template from the factory for the nose gear cut out? Is it generic or gear specific. I hate cutting this plane.......
Old 11-22-2014, 08:04 AM
  #73
EDFCrazy
Look at the two pics I've attached. one shows a piece of cardboard that i made up as a template.
I did this by placing the retract unit on top of a piece of card board then drawing the shape onto the cardboard below. I knew the shape would be right by doing this. Then i needed to place the template in just the right place at the bottom of the plane to get the cutout in the correct position.
I did this by placing the template inside the plane and using the retract former and the center mold line to get it into the correct location, then taped it into position inside. I then drilled two small holes through the center line if the cardboard and through the plane. I then placed the template outside of the plane and put two screws through the hole in the template and through the hole i drilled in the plane. this positioned the template the the right place on the outside. Then i taped it again into position and marked it out and then cut using a dremel.
ID:	2049288   Click image for larger version
Old 11-22-2014, 08:29 PM
  #74
smitty9969
My Feedback: (7)
Smitty,
Good morning Satdave..
I've enclosed a link to a build pictorial.
The gear featured is from airtech.de. That's the gear we sell from the factory..
https://www.dropbox.com/home#!/home/...lding%20manual
Old 11-23-2014, 05:45 AM
  #75
satdave
satdave's Avatar
I'm using the Airtech gear as well........having some trouble getting the link to work.
