Powerbox and Futaba S-Bus?????
Guys, Are you both using telemetry?
My royal SRS Rx status light on the secondary reciever flickers.
if the 7003 is using telemetry faster than 1s refresh, the Rx status light will flicker.
The faster the refresh rate, then the greater the rate the fades accumulate.
In the twin 7008 setup, it's even worse- the only way to stop a continuous increase of fades is to disable the telemetry.
Interestingly telemetry sensors only connect to the primary receiver, and yet it is always the secondary that shows the fades.
Any idea what's going on?
I am using a 12FG radio, and bought last year the powerbox cockpit srs. I am planning to use it soon on my CARF hawk , does the cockpit srs with 6303SB receivers work with the 12FG?
thx
thx
I use that configuration on two of m'y planes. PB Competition + 2x R6303SB Rx. The competition and cockpit are nearly the same boxes.
My Feedback: (41)
Anybody run the questions past the PowerBox folks?
I'm a jet newbie and have one plane with the JR 12X and DSMX setup but my new Avanti S has the PowerBox Royal SRS with the Igyro. Since I kept seeing references to some sort of problems with the PowerBox units and the R7008SB rx's with telemetry enabled, the two 7008's I originally bought for that model are sitting here on my desk and the model has a pair of the 6303SB's installed. Haven't flown it yet but a friend has the same rx's with a PowerBox PE in his big Tomahawk Futura and it's been fine.
