Tomahawk Futura 1.9. - fully airbrushed design
Hello, I would like to post pictures from airbrushed Futura 1.9. which is currently ready for final set-up. After that I will post additional information about final set-up together with building information.
Awesome paint job.
Love you charging ports and the large open space with the canopy off.
Look forward to seeing the maiden.
Paul.
Paul.
Nice Futura, great work.
My advice: securing your tubes with binding wire, and not with cable ties, even at the pump fittings, should give you a better surface pressure for the tube and more security in feeding your turbine. Don't forget tube in tank.
