New Gryphon EVO - First Flight Report
Hi guys,
Thought I would share some pics of my new Gryphon EVO from yesterday's outing.
I had four great flights on it and really enjoyed the way it flew. The plane came in at 9.9kgs dry and is powered with a new M100XBL. The maiden flight was a non event, it only needed a click of up trim and a few clicks of right and it was flying level. It is a really smooth flyer and tracks very well in the air. I'm going to increase my flap from 50 deg to see if I can get a little more drag on landing but other than that all settings are perfect.
The quality of the kit is superb, lots of carbon, very light and very nicely finished and an easy build. I also outfitted the plane with Electron ER-40's, the new Xicoy trailing links and electric breaks. So far they are all working great and make it very convenient not to have to take my air gun to the field.
I've got some video from one of the flights (Not great but shows take off and landing clearly) and another with an on board video.
If anyone is building one of these I have a heap of photos from my build in an album on my FB page which should help you out. - https://www.facebook.com/aussiejets
http://youtu.be/R5yfDKdhZus
http://youtu.be/xmHVmvs7LfQ
Cheers
Jeremy
Cheers
Jeremy
I've now logged 9 flights on the gryphon EVO and am happy to report it is going well so far. The last few flights I have been really pushing it with a lot of full throttle flying. It performs large aerobatics really well and moves quite quickly once it is on step. The M100 is plenty of power and pushes it around nicely.
I upped my landing flap to 60deg and this really helps slow it down. I'm going to start playing with mixing in some crow as well. I used this on my Viper and I really liked the way it sat on landing approaches.
I was flying in a light cross wind and there was a bit of wiggle in the air but I put this down to the winglets as my viper showed the same characteristics in cross winds. I'm going to have a few flights without the winglets to see what it's like.
Electron gear got a good test as well at a fun fly I flew at on the weekend. The field we were flying at was quite rough and the gear took a beating and except for a bent nose pin from hitting the one invisible bump on take off (See pic) the ER-40 and Xicoy trailing link struts took the beating well. Retract mounts also were up to the job which is pleasing.
Newshound, Contact Mike of Jose, they should be able to help you out.
I've included a pic below of my EVO flying loose formation with my old GJC Viperjet which my friend now owns and flies. It was great to get them up together.
Cheers
Jeremy
Cheers
Jeremy
1cm in front of the leading edge of the spar. This was with winglets on.
Winglets off needed a click click or two of up trim as it felt slightly nose heavy
