UP@ & Tam FAil Safe unit
My Feedback: (167)
The UP2 essentially does the sequencing for the gear and doors as I understand it...is that correct? There should be no need for a separate sequencer (such as a jetronic sequencer) or any sequencing done in the transmitter.
I only need one small servo to operate the up2 and that is it, correct?
My Feedback: (167)
I suppose you could use a Y cable unless you need different doors to do different things as is required for some jets with some doors remaining open and some closing. Maybe this is what you are referring to?
Anyway, thanks for the help. I have always used the Jetronic valves and sequencers but the pricing for these has continued going up over the years so I thought I would try the UP2. This and a small servo is less than half the cost of electronic valves and a sequencer.
I have a UP3 but unfortunately it leaves the doors open on landing which I don't want.
