First Turbine Jet Question
Looking to get my first turbine jet. I am looking at the Navy Cat Jet sold new on the RCU classifieds. Anybody know anything good or bad about this jet. Price is right especially with the retracts, $600, and also it accepts the KingTech k80 which I thinking of going with. My other choice is the Turbinator ARF by DreamWorks also believe it will accept the K80. Don't like the $900 price tag though. I could build the Turbinator kit but don't know if I would be saving that much after buying all accessories and effort building. Would appreciate your opinion on these two jets. Thanks in advance for your help.
I've flown the Turbinator and it has a good flight envelope. Goes slow or pretty fast and lands easy. It would be a good first jet. Sorry, but don't have any experience with the other jet mentioned.
My Feedback: (10)
There is a great thread on the Navy Cat at:
http://www.rcgroups.com/forums/showthread.php?t=2095652
I bought one from Yong (the guy selling them here). A very straight shooter and a very smooth transaction. I have not flown in yet but know a few guys that have and I hear it is a very honest plane,
+1 on the turbinator. The navy cat has been a popular model also but is difficult to transport because the outer wings are not removable you have to remove the
booms and remove the entire wing or transport whole if you have a vehicle large enough.
The Turbinator would be my choice too, especially with the benefit of hindsight having had a couple of different "trainer" types. The K80 will fly it well (but can take a smaller or larger size engine too). Easy to build, fly and, if necessary, fix. Looks fantastic in the air as well.
Good point on the cost of retracts, I had forget because I did not buy mine all at the same time but I purchased the struts and then I used gear and wheels I had previously purchased.
Thanks for all the responses. Some advantages to both. Like em both. May get the navy cat first and get my feet wet, price is very attractive. But still like the Turbinator too. Decisions!! Again great help from you all. I will report back.
Take a good look at the Ripmax Xcalibur, it ticks all the boxes, well made,easy to assemble, huge hatch to get at the gear for install, simple single flap setup, readily available spares, good quality retract package designed for this plane that holds air. AND, it is one of the best flying jets out there,very easy to take off and land,forgiving in flight with no nasty habits yet totally aerobatic with an 80-100 on board. I would not be without mine. Not sure what the price is in the US but it will be competitive for sure.
I have a Navy Cat and the workmanship is very very good . I had a problum with the nose gear (cylinder only) I called Yong on SUNDAY and he called back 1 hr. later. I told him the problem and he said that he would send a new retract,I told him not the strut as I had crimped the stearing cables. Well 4 days later I received a whole new gear strut,wheel and all. Great customer service from Yong.You can make it disassemble by not glueing the stab to the boom and just use the 4 screws which screw into blind nuts.Plenty strong enough. You'll need air disconnects for the retracts. It would easly fit in a Smart car. I haven't flown it yet waiting for my turbine to come back from service.
Yes, the Xcalibur may be the one. Like the looks and all things mentioned above. I don't see how to order on the Global website. Do you have to talk to one of the advisors on the toll free number? Also will the KingTech K80 be a drop in fit?
http://www.globaljetclub.com/
Just wondering and wanting an opinion from you all. Should I start with an EDF jet before going Turbine? Just been flying jets on my simulator. I've been flying for a lot of years. Been flying IMAC Basic for the last two years. Your thoughts? Thanks.
My Feedback: (24)
I would start with a trainer jet, a new, (or good used from a known source), modern turbine, and help from an AMA waiver holder who is a good pilot (the two are not always related...).
Bob
One option would be to look at a 90mm JTM Viperjet and switch it from EDF install to a Wren 44 later on. One question comes to mind, do you have friends in your club that fly turbine? maybe a flight or two on a buddy lead could let you know how close or far away you are from jumping in to turbines.
Both good points. I think that the money I would spend on a reasonable size EDF I would rather put in on a Turbine Trainer. That is what I really want anyhow. I will have to travel about 30 minutes to another field that has a paved runway. Also our field does not allow turbine jets because of a small residential area somewhat close by. We have one turbine flyer who goes to that same field. I can do some training with him. Thanks for all the input. Very helpful.
My Feedback: (24)
As far as noise is concerned, you and your buddy should get your club members to measure the sound of your turbines (once you get yours) at the property boundary when you are flying. Because high frequency sounds travel less far, I'd be willing to be that the sound level from your turbine is lower that any prop plane that has an engine larger than .90 size or so. Its also much less objectionable to the whine of a gas/glow motor...
Bob
