Jet tronics dual action valve
Reply
Old 06-17-2014, 03:05 PM
never-enuff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Jet tronics dual action valve
Help! I've got a Airpower Pro sequencer and 2 Jet tronic dual action valves for gear and doors. I can not get the door sequencer to switch unless I press the button on the valve. Even pressing the manual button on the sequencer won't work it. Also the light on the valve does not come on with transmitter and rec on. If I activate it manually only will it come on. What am I missing? Thanks
never-enuff is offline
Old 06-17-2014, 03:06 PM
never-enuff
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Just to add I'm using mode 1.
Old 06-17-2014, 04:34 PM
melvin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would reset the sequencer, reset the valves and then rebind the receiver to your transmitter. Then start the process over as far as programming the sequencer. Also you have to make sure that you have 50 lbs of air pressure or you will get screwed up on the programming. Hope this helps some
Mel
melvin is online now
Old 06-17-2014, 05:49 PM
lookilook
lookilook's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Mel
If the above does not work then try to switch on rx while you have gear up sw to the up position and then cycle to gear down,This should energize the valves.
lookilook is offline
Reply
Display Modes
