New Jet legend F16 with rivets. Mark 2
Reply
Old 07-01-2014, 01:00 AM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default New Jet legend F16 with rivets. Mark 2
I have just finished and test flown my new F16 mk2 but Mark 2 the second one I have owned.
All has come good , I sold my first one of these and ordered another kit from Zed jets uk . The service was great from the English Uk distributor .
I do not usually revisit models but I loved the way the first one flew , the second one is just as good.
The kit arrived in perfect condition and took hours ,not days to build. The install is made easy as the factory does all the work of horn install servo trays done and a good supply of good strong fittings that work. All the gear and doors are pre- installed and again work perfect. This time I took the option of nav lights again excellent work from JL.
The fuel system is two fitted plastic tanks of 1.8 l each I piped these in my own Tygon and to a CAT.
The engine of choice was a Jetcat P180rx ok more than needed but gives great fuel economy , flights so far are of 7to 8mins. I used a Powerbox-system Gemini 2 power supply into a Futaba 14 channel rx. With a Bavarian Cortex demon gyro on rudder and ailerons.
Here are few pics.
ID:	2010320   Click image for larger version
Mark H is offline
Old 07-01-2014, 01:28 AM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
More pics.
ID:	2010323   Click image for larger version
ID:	2010324   Click image for larger version
ID:	2010325   Click image for larger version
ID:	2010326   Click image for larger version
Mark H is offline
Old 07-01-2014, 03:08 AM
marc s
marc s's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice indeed Mark, and thanks for the ongoing support on CAT fuel products
marcs
marc s is offline
Old 07-01-2014, 04:46 AM
raron455
My Feedback: (38)
raron455's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Gorgeous plane...
raron455 is offline
Old 07-01-2014, 04:57 AM
FalconWings
My Feedback: (57)
FalconWings's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Beautiful Mark!
(said it a long time ago, as close to BVM quality as it gets........time proved me right!)
FalconWings is offline
Old 07-01-2014, 05:32 AM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Marc S , Falcon wings , yes the quality is stunning. I usually paint my models inside to cover up the unsavoury glue seams but on this I have left it natural to show the quality , it also saves weight,
the small MKS servo activates the gear , brakes and gear doors using off set timings in the mix on transmitter.
Flying this F16 is an absolute pleasure it has such a wide envelope of speed and handling and then the landings even on a cross wind are very stable. I have used a single BVM air filler and a robart air pressure gauge , thus far I have had air in this plane gear up or down for 7 days with no leakage. I also noticed the new store are very light weight inc pylons , when I put the attachment points in wing , every one hit a hard wood insert as they are supposed to.
ID:	2010344   Click image for larger version
ID:	2010345   Click image for larger version
Mark H is offline
Old 07-01-2014, 07:51 AM
Starrjet2
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mark what's the price tag the way you ordered. The plane?
Starrjet2 is offline
Old 07-01-2014, 09:42 AM
Rider-60
My Feedback: (17)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very nice Mark,
is it an external paint job?
rgds
Florent
Rider-60 is offline
Old 07-01-2014, 12:42 PM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Florent yes it is painted out of mould and it is a very lightly applied,
hum prices, these can be attained from Jeff at www.Zedjet.com the uk agent for Jetlegend , as there are so many extras that can be ordered , cockpit lights smoke pump geardoors done so many ways to order.
Mark H is offline
Old 07-01-2014, 03:01 PM
astro281
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for show many detailed photos. How are the landing gears? Do they function correctly? Thanks.
astro281 is offline
Old 07-01-2014, 03:10 PM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes the gear has been faultless and has worked from the outset fine, my gear door clipard valve slipped and I lost air but now it is glued secure I have had no more problems the gear holds air and stays up or down with no losses at all. When the plane lands it also tracks well with good ground handling. The brakes are a little to sharp though , silicon spray needed here :-)
Mark H is offline
Old 07-06-2014, 05:30 AM
John Tancock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Mark
I see the the bolt holes have disappeared from the top surfaces!
Are these underneath again as the G1?
John Tancock is offline
Old 07-07-2014, 12:39 AM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi John ,
yes the retaining bolts are now in the undersurface of the plane , this means turning over to assemble but it is light so that's not a problem.
JL have also grooved the retaining bolts and added a cir clip so the bolts can not work loose during transport , all these little things make it such a great package. I am looking forward to more product from JL. Is yours flying yet. ?
Regards Mark.
Mark H is offline
Old 07-09-2014, 09:01 PM
Dieselman1220
My Feedback: (25)
Dieselman1220's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Heard a rumor this was the exact same kit as the premier/bvm 1/6 f16????????
Dieselman1220 is offline
Old 07-10-2014, 02:48 AM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This kit is manufactured by Jetlegend, many different companies market their product around the world , yes I think BVM aircraft looks the same very high standard as this kit. This is now my second Mk2 with rivets and both have flown fantastic . Attached is my first Mk2 in the blue aggressor scheme , this is now with a new owner.
ID:	2012986   Click image for larger version
Mark H is offline
Old 07-10-2014, 03:00 AM
jeff sewell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Probably like FB, built in the same factory as the JL F16...makes it more or less the same.
jeff sewell is offline
Old 07-10-2014, 03:27 AM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine did not come with servos installed , I think the BVM version does. :-)
Mark H is offline
Old 07-10-2014, 06:41 AM
Dieselman1220
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Right I knew FB and JL were essentially the same, I wouldn't be surprised if this is the same kit as the BVM/Premier. Premier might just take them and install all the electronics, fuel system, and air system. Ive been eyeing the BVM but if this is the same kit I may look into this. I would prefer to install my own electronics anyway.
Old 07-11-2014, 12:28 AM
John Tancock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sorry Mark, I was not egnoring you, Crappy time at work you know how it is!
To be honest with you I have only just acquired the last of parts required to complete this work of art!
The standard of this kit/ARF has really set a new benchmark for others to follow, and I don't mean the external finish either!
Mark, I am installing a Merlin 140 which is putting approx 34lbs of thrust, it would nice to compare the two on performance and economy don't you think?
Did you get the new light weight ordinance?
Regards
John
Old 07-11-2014, 12:42 AM
jeff sewell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi John,
I fitted the M140 in mine; excellent performance on this turbine. My friend said it was as good as his P160RX...
Have fun...
Jeff
Old 07-11-2014, 12:54 AM
John Tancock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Jeff
I need some SW's for the tips, have you got any in stock?
Regards
John
Old 07-11-2014, 01:16 AM
jeff sewell
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi John,
I thought I had but they sent me the ones from the next pylon along (AMRAAM?) inadvertently.
I can add to the next order...
Cheers
Old 07-11-2014, 01:41 AM
Mark H
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi John , yes I have the new set from Jeff, said it was for you or some thing beautiful sidewinders, no not really :-)))))))
yes I have got new stores on , yes , I know how you feel about quality it is some thing else. As for power you flew my last one with the P180 rx and although it sound more power ,I,m not using it all only on climb outs and HA, the fuel consumption is great in five mins I use just one tank so 8 mins is possible I think . I have moved batteries forward so bring c of g forward it is so much better.
Mark H is offline
Contact Us Archive Advertising Cookie Policy
