Reload this Page >
kero start wren spitting flames?
Old 07-02-2014, 10:42 PM
bluescoobydoo
Default kero start wren spitting flames?
I have a new Excalibur that I was going to fit a wren 80 kero in and I was trying to find out from owners if they spit much flame out of the back on start up. I don't want a bbq on my first flight!
Old 07-03-2014, 12:18 AM
Justflying1
It's always a good idea to get a steel tube on a small stand to put behind the turbine on start up especially with Jets that have the stab and booms behind. This way on a hot start if you have one no damage will be done.
Old 07-03-2014, 02:41 AM
alasdair
alasdair's Avatar
My Wren Jubilee starts smoothly quietly and cleanly.
But yes, it will not do any harm to protect the tail with a metal tunnel until you are sure.
Old 07-03-2014, 03:47 AM
Boomerang1
Boomerang1's Avatar
Or just a piece of flat sheet metal bent at about 90 degrees, sort of like a little tent. - John.
Old 07-03-2014, 04:37 AM
Dr Honda
Dr Honda's Avatar
Aluminum tape under the elevator will help. The tube is the ultimate in safety... but it's a pain to use all the time.
Old 07-03-2014, 04:53 AM
gooseF22
gooseF22's Avatar
When the Jubilee is set up right, it starts very smoothly.. Before you buy it, it is run on the test stand and tweaked a bit.
It also helps to never start into a tailwind.
Run the motor a few times without the tail or with a pipe after setting up. before first flight...
I put alum tape on the underside of the stab on all my high tail units just as a precaution..
Old 07-03-2014, 12:52 PM
Art ARRO
I recommend lowering the Pump Start Parameter a couple of units to eliminate the flaming during startups. See the Troubleshooting Section of the Operators Manual for further discussion on this. It's call an "aggressive start".
Also, I noted that you're in the UK and I would ring up Wren directly for their advice on this. I recently had an issue with my Wren 44K Gold and Mike himself sorted it all out- now starts and runs just fine afterwards.
Rgds,
Art ARRO
