xicoy FADEC with P-60 Question
#53
HA! Thats great John!
Ok... one more hill concurred and another hill behind it. But Im allllll most there. So I lowered the Speed Stop to 40,000. I could see the rpm's drop just below 45,000(previous setting) for a second and that was enough to kill it. Now she has leveled off and does not quit anymore. The next hill to climb is the Throttle Down. When I lower the throttle stick... the rpms remain high for longer than I would like, and then they gently start to come down. If this were in the air.. the plane would be another 3klm away before loosing speed. Is this now the time to lower the Deceleration delay from 10 to perhaps 5 ?
Thanks again guys for the help.
BTW.. this little sucker is LOUD!!!!
#55
Just saw the thread.
I have modified 2 JC P-60 and 2 JC P-120 for two guys of my club with xicoy fadec, and all of them run perfect.
For both P-60 I used one hall sensor from xicoy with the JC magnet, ad used the same egt sensor, from jetcat, ( you have to pic up the signal from the external conectors of the sensor, desconected from the electronic JC board.
For the P-120, in one of them I used the optical sensor from jetcat, ( and for this I had to order a special fadec from gaspar, ( two pulses rpm)), For this, you have to modify a little the electronic board, ( invert the protection diode, and the wires of the electric motor), and so, for the second one, I used the easy way, and I installed a magnet inside the compresor nut, and used a sensor hall from Xicoy and a standard fadec.
One problem that I had with the four turbines, is that i you route the starter motor wires using the electronic board, you will have trouble with the magnetic sensor in the starting process, making it cahotic. The better way is to make a hole on the front cover of the electric motor, and roue the wires from here.
All this engines start and run perfect, if you need the parameters, le me know. I think that I have pictures too.
Here is a starting of the modified P-120 with the optical sensor
https://www.youtube.com/watch?v=ELZy...AnizxsJrreIRMg
Edit: ust found a picture of one modified P-60
#56
This is also an effect of the learning process of the ECU. You just have to run it and tear your neighbors ears
You should be able to lower the deceleration delay as much as you want, as long as the engine can hold the flame while spooling down. Don't exaggerate or you'll end up flaming out on a power down dive in flight!
If you use diesel you'll have some tell-tale signs when the deceleration is too quick, that is, white smoke puffs. My kingtech was doing that and eventually it flamed out during a steep spooldown on the ground. Raising the deceleration delay by 2 points made it rock solid
#57
OK Thanks mauryr. I'll run her up as you suggest.
Actually the neighbors are all really good people. Many have come over to see whats going on over the years, and all are fascinated. But! I think its ok so long as I dont continually run the engine.. the last few days is the most noise ive ever made and I dont want to push their patients Respect thy neighbor
#59
#64
The xicoy hall sensor works without adjusting anything. Just mount it to the engine and plug it in. Reads the RPMs the way its supposed to. I didnt even raise it up to the location that JC has theirs mount.
#65
This is my setting: ( In red color, at the right side of your settings).
START Menu
Max RPM 165,000 165.000
Min 50,00 55.000
Pump start auto-3 auto+0
Start Ramp 8 7
plug v 2.4 ok if gas ignite.
gas 100% 100%
Low voltage cut off 6.v 6V
Start power at ignition 68 35
Ignition max rpm 6000 5000
min.....................6000 2000
preheat 2 seconds 2
gas off 45,000 (I dont use a gas solenoid. I feed direct from bottle) 40.000
starter at fuel ramp 96 35
RPM 100% starter power.. 22,000 rpm 28.000
RPM OFF Starter 27,000 35.000
reconnect 25,000 30.000
RUN Menu
Max temp 800c 800
Start min temp 100c 100
Stop Speed rpm 40,000 38.000 ( but 40.00 is ok)
pump limit 812 ( I prefer 1020 and don´t use it, but 812 is ok)
accel delay 009 I had to raise it to 30, and acceleration was very fast
decel delay 010 35, you will have to play with accel and decel delays when you test it
stability delay 096 60
There are 5 more parameters that afect to the ramp point, and have no acces from the main menu. ( that change the ramp value depending with the rpm in three diferent points . If you see that the turbine start very fast or with flames, you will have to change them too. The only way is from the advance menu, ( start the fadec, and BEFORE the start message disapear, press data down and menu down. You will enter to a menu when sows the parameter and the value. )
Chenge as follows:
Parameter 026 Value 038
Parameter 027 Value 045
Parameter 028 Value 001
Parameter 029 Value 000
Parameter 030 Value 000
Keep us informed.
Félix
START Menu
Min 50,00 55.000
Start Ramp 8 7
gas 100% 100%
preheat 2 seconds 2
RUN Menu
Max temp 800c 800
Chenge as follows:
Keep us informed.
Félix
#66
Wow Felix... Your numbers vary much from my settings. Given that you have done 2 P-60's and they run.. I will have to give your settings a try.
Thanks very much for taking the time to post them here.
#67
Hi Felix. I have set your parameters and mounted the engine back on the test stand. But I cant seem to access the RAMP Parameters. I have tried several times to enter by pressing the Down Arrow and the Negative symbol just as its turned on.. but it just takes me to the main menu?
Any thoughts? This is the Au-108k ecu if that matters..
Ok guys... What gives now?? I tried to start it with Felix's settings but the starter just kept pulsing on and off. So I went back to me original settings and now Im getting this.. The RPMs desplay 65000 right from the get go and then they drop, but then I get the starter overload warning. Check out the video. The battery is fully charged. If I spin the compressor by hand...the rpms read correct.
https://www.youtube.com/watch?v=bVqNkd2DhBs&feature=youtu.be
#71
This is the gas ignite sequence, I understand that the gas didn´t ignite isnt´it? If this doesn´t happends, you have no start. Before you had a continous rpm, but this is not the way to go with a xicoy fadec and gas start. Check.
Before you had the rpm steady for the ignition phase, now ypu have a pulse between 5000 and 2000. All xicoy fadecs works like that in the starting.
Try to ignite the gas, and yu will have a steady start with the parameters that I show, belive me..
Félix
Félix
#72
Be sure that you route the starter wires by the front side of the starter, ( not internally, nead the rpm sensor) this strange reading of the rpm are produced by the interference of the glow plug.
And the overload is because you have a very high start power at ignition
Félix
Félix
#73
Ok Felix.. But it started several times before with my settings. But yes I will move the started motor wires to the front.
Do you think there could be a problem with the Red glow wire as I have cut and soldered it to make it shorter.
#74
Félix
Félix
#75
Felix is correct. You also need to twist the glow wires together this usually stops it.
john
