Reload this Page >
xicoy FADEC with P-60 Question
Old 12-05-2015, 06:30 AM
  #101
Vettster
Vettster's Avatar
Hi Ray.. I did not know about the optical RPM sensor... and I think that would complicate things. Gasper(xicoy) has said that he has done P-80's in the past.. but those I believe where the older version.
To be honest... there are thousands!! of P-80se's out there, and with that there are hundreds that have found the grave yard.. Best to place an add here on RCU and RC..Groups asking for an ECU. It would be much easier.
Good luck
Trevor
Old 12-06-2015, 01:48 AM
  #102
Ray Millington
Hi Trevor,
Thanks for the reply re P80se and Xicoy ECU,
If i have any news i will post it here,
regards Ray.
Old 03-08-2016, 11:44 AM
  #103
Ray Millington
Hi all,
I hope this thread is still active as i found it to be great to follow Trevors (Vettster) epic journey ,Modifying his P60 to run with Gaspers Xicoy V10 ecu,
Following the information found here i have successfully converted a TJT 3000 turbine with very low hours on it,
I now want to convert a JetCat P120 using the Xicoy V10,
Can FELIX BARRAO who has done this successfully please inform me what his settings for the Xicoy were
The main reason i prefer to use the Xicoy ecu are,
I use the Jetti 16DS radio and the telemetry outputs from the V10 to the 16DS is amazing,
I hope you can help me Felix?
Thank you in anticipation,
Best regards
Old 05-18-2016, 04:12 AM
  #104
Ray Millington
Hello Felix,
I did send you a personnel message ,not sure if it got to you,I was on holiday in Florida at the time,
So i hope you read this old thread,
I was hoping you could share your p120 Xicoy V10 settings please,
regards Ray
Old 08-01-2017, 03:53 PM
  #105
Keron232
Default Xicoy v10 fadec
Hey guys I have a xicoy v1p fadec and the starter , glow plug , fuel and he valve doesn't work only the pump function works. But when I test them externally they work. Is there a way to reset the fadec?
Old 08-02-2017, 07:30 AM
  #106
i3dm
My Feedback: (51)
try the "test plug" and "test starter: functions - if they dont work then, the ECU is damaged.
Old 08-02-2017, 05:36 PM
  #107
Keron232
Default V10 fadec
They don't work only the pump circuit works. Am doing a project here building my own turbines and in the process of making a helicopter turbine like jetcat pht3 , am using their frames tho. Am using a 74mm compressor wheel and 70mm turbine wheel. So I plan on using an xicoy v10 eeach project is 95 percent complete pics coming soon expected 40 pound's thrust but will limit it through the fadec. Is there anyone willing to release a used v10 fadec.
Old 08-03-2017, 06:15 PM
  #108
Keron232
Default Xicoy v10
Hello guys I found what was the problem I opened up the ecu and low and behold there was a burnt stip on the board I soldered it together and everything works. Now it's set to kerostart and it has a feature to change to gas start which I want to use but some of the parameters are locked due to my friend bought it from kingtech. It's and AU -108K WOULd the limited settings in auto start work for me? Please help I don't have access to some features like pump voltage and starter rpm and others , only can adjust a few items
Old 08-05-2017, 05:55 PM
  #109
Keron232
Default Xicoy v10 Au-108k
Do anyone know how to access the hidden menu on the kerostart xicoy v10 fadec. I want to use auto gas start on the fadec instead of the kerostart but some of the parameters are locked or missing I cannot access the pump parameters and starter rpm , ramp and others please tell me how to access it.
  #110
Keron232
Old 07-16-2023, 10:03 AM
  #111
i3dm
My Feedback: (51)
Sorry to bring an old thead back to life, but im trying to increase MAX RPM on my Xicoy AU-108K. its curently limited to 124.000 and i need it at 160.000.
does anyone know which parameter in the service menu opens the top RPM limit?
was told paramete 048 but my service menu only goes up to 031.
any ideas?
Old 07-16-2023, 10:34 AM
  #112
CRX Turbines
It sounds like you have a manufacturer branded ECU. There is no way to unlock this at least not you or I. You can perhaps send to Xicoy but contact them before doing this. if you elect to purchase a new one direct from Xicoy there won't be any set limit.
Andy
any ideas?
Old 07-16-2023, 01:56 PM
  #113
i3dm
My Feedback: (51)
Andy
thanks Andy.
Gaspar was kind enough to offer assistance and now its unlocked and reprogrammed.
thanks gaspar.
