Carf - Models J-10 build thread
Old 04-02-2018, 03:15 AM
  #226
number27
number27's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I notice the Thrust Vector nozzle sits sticks out past the tail-cone.Mine is tucked away inside standard build. Is there some mod made to this one to have it extend past the tailcone. I have had to tame the TV nozzle down because it would burn the end of the tailcone.
number27 is offline
Old 04-02-2018, 03:56 AM
  #227
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
We cut the tailcone shorter....
Dave Wilshere is offline
Old 04-02-2018, 04:14 AM
  #228
Andrew Bird
Andrew Bird's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Dave! Think this was my favourite shot from Yesterday.
Andrew Bird is offline
Old 04-02-2018, 07:09 AM
  #229
number27
number27's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Explains that. Was considering that move. How much was taken off?
Tks for the reply
number27 is offline
Old 04-02-2018, 07:40 AM
  #230
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tks for the reply
About 2"
Old 04-02-2018, 05:59 PM
  #231
number27
number27's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
tks will review trimming some off.
number27 is offline
Old 04-03-2018, 06:26 PM
  #232
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am looking for help on best way to set up a demon cortex gyro in this airframe
roydefiant is offline
Old 04-30-2018, 09:32 AM
  #233
jdlilfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I am looking for the same, decided to go with a Cortex pro. Anybody have gain settings to share? All I have is the blurry copy of the iGyro setup from the instruction manual.
jdlilfan is offline
Old 07-20-2018, 07:02 PM
  #234
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I will ask again. Anyone with experience using a cortex demon gyro in this J10?
Old 07-20-2018, 10:42 PM
  #235
dappe69
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
contact me thruu messenger. d.viklund@hotmail.com
dappe69 is offline
Old 07-21-2018, 01:16 AM
  #236
jdlilfan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm using a Cortex demon pro with jeti CB200. My gains are still a work in progress but right now I'm around 38 for normal mode and 42% for hold mode. I might increase the hold mode gain some more, not sure if I want to increase normal any more, need a calm wind day to test some more. I think I was one of the few using the Cortex pro in this, so everything for me has been experimenting. I had no ones other numbers to go off of.
jdlilfan is offline
Old 08-05-2018, 05:41 AM
  #237
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have been watching you tube footage of this model. Appears some pilots land with canards disengaged and others land with canards engaged (maybe lower rate). As I am programming mine now would like to get others experience with regards to canards and landing.
Old 08-05-2018, 08:29 AM
  #238
andykane
My Feedback: (58)
andykane's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hello, Roy, I use Low rate Canards for normal flight and landing and High Rate Canard for 3D.
Andy Kane
CARF MODELS
andykane is offline
Old 08-05-2018, 03:36 PM
  #239
roydefiant
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Andy, thanks that makes sense. Would you mind sharing your high and low rate canard throws and whether you measure them from leading or trailing edge of the canard
Roy
Old 08-06-2018, 06:41 AM
  #240
andykane
My Feedback: (58)
andykane's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Low rate canards 10 degrees up and down 3d Canards 40 degrees up and down, be careful on the high rates and really only used at low airspeeds.
Andy Kane
CARF Models
andykane is offline
Old 10-08-2018, 04:51 AM
  #241
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Some J-10 action yesterday.
Old 04-27-2019, 02:55 PM
  #242
Moebius44
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Folks,
Going through test flights / setup, trying to come up with heading / heading hold values. Although this is not a CARF version, it is exactly the same size. The iGyro 3e has heading (Range A) set to at present to 40% and experienced oscillations. Heading hold (Range B) is set to100% for 3D...
I'm curious what folks are setting theirs at for heading (Range A).
Many thanks.
p.s. Given the black paint job / honeycomb / Airex airframe I needed to make a cover. I ended up using an awesome / stretchy material that acts as a great sunshade. I made a few for friends and have one extra in the color your see, if anyone is interested;
Moebius44 is offline
Old 05-02-2019, 09:42 AM
  #243
Moebius44
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No one uses a gyro on this airframe??
Old 09-18-2019, 10:39 PM
  #244
laiqalih
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I need help for gyro settings in FM 2 and 3 what should be the gains,
laiqalih is offline
Old 09-19-2019, 12:03 PM
  #245
Dave Wilshere
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
When you ask questions you need to give all the info! So which part, airframe or vector. What gyro!
Old 09-19-2019, 09:01 PM
  #246
laiqalih
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Complete gyro settings for plane and vector. Carf j10. Powerbox mercury . FM2 and FM3
laiqalih is offline
Old 09-21-2019, 05:37 AM
  #247
airborn900
My Feedback: (23)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sub
airborn900 is offline
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
