Reload this Page >
Demon Cortex Gyro question
Old 04-12-2015, 05:32 AM
  #376
KFX450
My Feedback: (30)
Figured. Thanks a million.
Old 04-13-2015, 04:40 AM
  #377
BarracudaHockey
BarracudaHockey's Avatar
The good news, if you're flying Spektrum and have the channel on your radio, the 9020 is actually a 10 channel receiver
Old 04-19-2015, 01:50 PM
  #378
mavrick
Hi Guys.
This question may have been asked I am putting Gyros in all my jets I have just finished switching them over to my new system (Jeti ) the last one is my Raptor, can I do this with tailerons and the question raised was with the bit of free travel on the tailerons will this affect the gyro and possibly start flutter.
Cheers
Mav
Old 04-19-2015, 03:16 PM
  #379
Bob_B
Bob_B's Avatar
The Cortex learns your setup during the teaching process. Free play is a bad idea on any model and should be removed.
Old 04-19-2015, 05:08 PM
  #380
mavrick
Bob I have not seen a taileron setup yet that has no movement mine has about 3 mm and for what I have seen that's pretty good.
Cheers
Mav
Old 04-19-2015, 05:18 PM
  #381
gunradd
My Feedback: (9)
gunradd's Avatar
Mav I have my cortex on my F22 on tailerons and the ailerons works perfect very happy with this set up.
Old 04-19-2015, 05:25 PM
  #382
mavrick
Thanks Gun how much movement have you got on your tailerons as I just said to Bob I have about 3mm and there is no way I can get rid of it I have tried Man have I tried, all the flying stabs that I have seen have a fair amount of movement some I would Sh##t myself if it was my aircraft LOL
Old 04-19-2015, 06:30 PM
  #383
hoser
hoser's Avatar
hey bob does it learn elevons without having to use a software set up
Old 04-19-2015, 06:33 PM
  #384
Bob_B
Bob_B's Avatar
Yes the Cortex learns your control setup during the programming phase!
Old 04-24-2015, 06:58 AM
  #385
Reever45
My Feedback: (16)
Does anybody know if using sbus, if you can remap the channels numbers higher than the default of 1-8 ( like 9 or 10 or whatever)?
Old 04-30-2015, 05:46 PM
  #386
gooseF22
gooseF22's Avatar
Originally Posted by jws_aces
I have 2 servos on the elevator. I just finished setting it up. I am going to use the knob to adjust the gain for the first flights. I have the travel set to off then to normal mode. I adjusted the travel so the hold side will not work. I lower it to 0 on that side of the travel for the channel I have the gain plugged into.
Any suggestions on first flights?
That is exactly what we recommend doing.. use the knob.. we recommend putting using your dual rate switch to lower the expo..
so when you takeoff the first time, everything is as you normally fly.. then dial up 30% expo to begin with.. then switch to the rate with less expo, about half.. it should feel similar, but be stable as a rock..
we rarely end up over 60% overall because of the risk of overlain at high speed.. anyway when you find the locked in feel value, then you can lock it into the flap switch..
So for instance if the value is 35% at cruise, then I lock in 40% for takeoff flap, and 45% for landing flap.. that works well for me to keep the feel consistent.
Exceptions are delta wing aircraft.. they require a lot more rudder dampening.. so we go into the software and lower the elevator/aileron values, and then dial up the gain 60-99% or so..
Old 05-01-2015, 02:43 AM
  #387
Bob_B
Bob_B's Avatar
[QUOTE=Reever45;12027993]Does anybody know if using sbus, if you can remap the channels numbers higher than the default of 1-8 ( like 9 or 10 or whatever)?
Thanks[/QUOTe
yes on certain models I know the 6208 does not work.
Old 05-01-2015, 03:31 AM
  #388
Mi-25
Not totally correct - if you use the PC software you can assign different gains to each axis.
Old 05-01-2015, 03:43 PM
  #389
gooseF22
gooseF22's Avatar
In the software you are assigning the relative bias gains.. the master gain still controls overall gain.. the software controls relative gain from 0-20.. be careful with relative gain.. a little change goes a long way..
Old 05-01-2015, 05:01 PM
  #390
Mi-25
Hi Goose - agree....100% correct...adjusting master gain changes overall gain irrespective of whats set as relative channel gain...so the guys need to be a little careful.
Old 05-07-2015, 12:01 PM
  #391
sskianpour
Old 05-13-2015, 10:15 AM
  #392
uLTRASPORT1000
My Feedback: (8)
I have been using the Cortex on several of my planes both turbine and prop and have no issues. I was just wondering if anybody has done a direct comparison of the Cortex vs I-gyro 3e?
Sam
Old 05-13-2015, 11:16 AM
  #393
gunradd
My Feedback: (9)
gunradd's Avatar
Sam
Allot of my friends using the 3E love it and prefer it. I prefer the cortex. I tried the 3E for 8 flights and just did not at all like it. The cortex on the same day was fine from the first flight. Not sure if its the plane type or maybe its how I fly not sure. Its more of a preference thing I guess. I also like how you can do ailerons and tailerons with the cortex at once right out of the box just with the learning procedure.
They both have good reputations so its personal preference.
Old 05-13-2015, 06:22 PM
  #394
hoser
hoser's Avatar
it is personal choice... I have a 3E on my BVM 86 set up by Ali and a Cortex on my BVM T-33 set up by the rep and VERY happy with both and they both do the trick VERY well. I also can confirm when I spotted for Gun at FL jets and I saw him use both back to back I clearly saw that the Cortex on his 22 had better results with a straight drop in install on his airframe.
Old 05-13-2015, 06:36 PM
  #395
uLTRASPORT1000
My Feedback: (8)
Thanks for the info.
Sam
Old 06-29-2015, 07:27 AM
  #396
George
My Feedback: (57)
Okay, I've searched for references on the "alternate" mounting options for the Cortex, but not having much luck finding anything. Anyways, we installed the gyro on the vertical plane and there are two options for this in the software (L Vertical & R Vertical). The 'question'...which is which?
If you were sitting in the plane facing forward, the gyro is mounted with its base on the right side and the sockets facing left & forward. I naturally assumed this was R Vertical...yes/no?
I did switch it to L Vertical very briefly to do a cursory check, and didn't see any change in direction, but I may not have thoroughly vetted that set-up, so know I'm questioning it altogether. We have 'semi' successfully flown the plane with the R Vertical setting, but are still needing to tweak things and was questioning the mounting setting again. Does anyone know for certain about the vertical mounting?
Old 06-29-2015, 08:03 AM
  #397
Bob_B
Bob_B's Avatar
If you have it with "labeling" facing left choose left and Visa Versa, reason being it came from the helis gyro which would be mounted on the outside of the frame work.
Old 06-29-2015, 08:05 AM
  #398
Bob_B
Bob_B's Avatar
George will you be at JOK? If so I would be happy to show you the Gyro menu in depth.
Old 06-29-2015, 08:12 AM
  #399
George
My Feedback: (57)
Bob,
That makes perfect sense...(now!)
Yes, I'll be there on the 7th, but not sure if the plane will be or not.
Old 06-29-2015, 08:27 AM
  #400
George
My Feedback: (57)
Bob,
Just for clarification "labeling" facing...as you view from the cockpit facing forward, correct?
