Reload this Page >
Skymaster Avanti XXL Build Thread
Old 11-13-2014, 09:50 PM
Helijet
111 mm OD
Kingtech 210
Dean W.
Old 11-14-2014, 12:42 AM
In the Haze
In the Haze's Avatar
110mm od.
Kingtech 210.
Old 11-14-2014, 07:19 AM
FenderBean
FenderBean's Avatar
So it looks like 110mm for K210 Class turbine and My thrust pipe is 125mm for Mammoth size pipe.
So I did some clean up on the tank mod and I decided to give the gear doors a nice coat of black paint, they had paint on them from the factory on the inside and just didnt look professional to me.
I also add two small brass tube pieces to each gear to hold the brake line in place, I hate zip ties on gear struts. Just a personal thing, I will also not be using zips on my wires anymore I have a great solution for this and its much better and as small as it is will save weight.
ID:	2047332   Click image for larger version
ID:	2047333   Click image for larger version
ID:	2047334   Click image for larger version
Old 11-14-2014, 07:50 AM
schroedm
schroedm's Avatar
Let me know how you get on installing the horns. The supplied horns are short with hardly any rake on them. You can't get the pivot point over the hinge rod as the support block appears to be set further back in the surface. I had to 'lean' mine forward as best I can. Not ideal but not gonna make a huge difference so long as both sides are in the same position.
Will post pics etc of mine over the weekend
Old 11-14-2014, 10:31 AM
FenderBean
FenderBean's Avatar
i noticed my blocks they added after the jet was built are to far back as well. They do the same thing as all the other guys they just dont pay attention to the details sometimes. I may use different control horns on mine, the problem is i got an email from dreamworks and they are out of futaba arms i need. They sent one futaba and 4 JRs and im not going to start cutting until i can get all the arms on and attach the control rods. The good thing is the pivot points of the control surfaces are back so well see.
This project is playing hard to get, killing the motivation.
Old 11-14-2014, 06:06 PM
  #31
Helijet
Looking at the layout of components. Lots of room which is nice
Dean W.
Old 11-14-2014, 08:14 PM
  #32
FenderBean
FenderBean's Avatar
Helijet, I noticed I have two main tanks and one smoke tank, did yours not come with three tanks?
Before heading out tonight I managed to get the servos for the elevators in they face in towards the tip of stab. Nothing major just a simple four screw setup to hold them in and I made some ply mounts for the nose gear servos as well and will glue them on next
New Video is uploading on my Youtube page
ID:	2047448   Click image for larger version
ID:	2047449   Click image for larger version
ID:	2047450   Click image for larger version
ID:	2047451   Click image for larger version
ID:	2047452   Click image for larger version
ID:	2047453   Click image for larger version
ID:	2047454   Click image for larger version
ID:	2047456   Click image for larger version
ID:	2047457   Click image for larger version
ID:	2047458   Click image for larger version
ID:	2047459   Click image for larger version
ID:	2047460   Click image for larger version
ID:	2047461   Click image for larger version
ID:	2047462   Click image for larger version
Old 11-14-2014, 09:23 PM
  #33
Helijet
Correct..only 2. I have not measured the capacity but I suspect that the large tank I have is for fuel at 5.2 L. The smaller is 2 litres for smoke. You have an extra 2.5 litres for the larger engine displacement which would make sense as you have the larger thrust tube?
Dean
Old 11-14-2014, 10:40 PM
  #34
FenderBean
FenderBean's Avatar
I thought the larger pipe and extra tank was only for the BF300 setup, that being said the BF300 is about the same in fuel usage. Thanks for the info, after seeing how tail heavy the thing is I will be putting in some boards further into the nose over the nose wheel to help balance things out.
Dean
Old 11-15-2014, 03:36 PM
  #35
FenderBean
FenderBean's Avatar
Well back at it after, started on installing the fuselage stuff today, I am moving my power system further up the nose closer to the battery tray. This jet normally comes out tail heavy and to prevent adding weight I am moving stuff as far forward as possible. I made a mount and laminated it with carbon fiber to increase the strength, I could have used thicker ply but I have some materials I need to use up before they go bad. Plus its just more fun !
While that is setting up I moved on to the nose gear door servo mounting, both are in place and cured. Before taking a break I started marking the layout on the base board I will be using and getting ready to mount things.
I put another video up on my youtube site should a few things! Roll Tide!
ID:	2047610   Click image for larger version
ID:	2047611   Click image for larger version
ID:	2047612   Click image for larger version
ID:	2047613   Click image for larger version
ID:	2047614   Click image for larger version
ID:	2047615   Click image for larger version
ID:	2047616   Click image for larger version
Old 11-15-2014, 04:16 PM
  #36
FenderBean
FenderBean's Avatar
Cool
[attach=config]2047628[/attach]
roll tide
Old 11-15-2014, 05:17 PM
  #37
RC_MAN
I'm building one of these also. It's a love Hate relationship
I like the brass tube idea to hold the break lines, what kind of glue and surface prep did you use?
Old 11-15-2014, 08:27 PM
  #38
FenderBean
FenderBean's Avatar
I recommend some kind of hysol epoxy, and I just cleaned the area real well. I HATE zip ties
Old 11-15-2014, 08:44 PM
  #39
FenderBean
FenderBean's Avatar
Well been busy tonight working on getting the equipment in for the air stuff. I made some mounts for my robart two-way valves and my UP6 brake valve. They will be under my base board so it will have a nice clean look once everything is in. The mount for the Robbe/Futaba battery backer will be ready in the morning so I will finish up the power system then and get the servo wires ran and al the valves hooked up. I went ahead and rough cut the holes for the brake/gear air lines, I think the a three line flush type would have been real easy to install on this jet.
Not sure how much more I will get tonight since the resign is still setting up but I do have another video uploading.
ID:	2047677   Click image for larger version
ID:	2047678   Click image for larger version
ID:	2047679   Click image for larger version
ID:	2047680   Click image for larger version
ID:	2047681   Click image for larger version
ID:	2047682   Click image for larger version
ID:	2047683   Click image for larger version
ID:	2047685   Click image for larger version
ID:	2047686   Click image for larger version
ID:	2047687   Click image for larger version
ID:	2047688   Click image for larger version
ID:	2047689   Click image for larger version
ID:	2047690   Click image for larger version
ID:	2047691   Click image for larger version
ID:	2047693   Click image for larger version
Old 11-16-2014, 12:27 AM
  #40
FenderBean
FenderBean's Avatar
Well, I remember why I hate air systems, the dang airlines are still a pain even the few I had to do on this one. I glued in some small hose clips to keep the lines in place and I use 4 disconnects on the a few areas to allow for the base board to be remove and disconnected from the fill ports and brake lines. I will finish up the mounting of electronics tomorrow and after that its just add the fuel system. Then I have to wait on the servo arms and turbine stuff to do the pipe.
ID:	2047702   Click image for larger version
ID:	2047703   Click image for larger version
ID:	2047704   Click image for larger version
ID:	2047705   Click image for larger version
ID:	2047706   Click image for larger version
ID:	2047707   Click image for larger version
ID:	2047708   Click image for larger version
Old 11-16-2014, 08:44 AM
  #41
mr_matt
My Feedback: (10)
mr_matt's Avatar
How much ATV are you going to need to use with such long servo arms?
Originally Posted by FenderBean
Okay so the corrected servo box issue is curing and the servos are mounted via your typical "L" bracket with screws and washers.
I have to get longer servo Arms, looks like 1.5 inch arm will work for everything, the flaps and Rudder need the longest arms. You could even use a 2 inch on the flaps and rudder, but i going 1.5 if I have to cut more area for the arms I will.
Old 11-16-2014, 09:06 AM
  #42
FenderBean
FenderBean's Avatar
I'm Not Sure Until I Get Everything Hooked Up. Based On Th Throws In The Book And Considering It's A 3d Jet I Will Prob Want Need Much. I Do Have The Ability To Move Down On The Servo Arm For The Aileron. I Normally Don't Lower In Points Much To Prevent Losing Resolution. Sorry For All The Capitol Letters For Some Reason When I Use My Phone On Rcu It Does This.
Old 11-16-2014, 03:51 PM
  #43
FenderBean
FenderBean's Avatar
Well all the electronics are in and all the air system is in as well. That leaves the fuel system, turbine and pipe to install, oh and the control arms once the correct futaba SWB arms ship from dreamworksrc. I really like how my carbon mount turned out for the battery backer, gives a nice strong mount and plenty of work around space. I made some mounts to support the mount and used hysol to glue it in, the mounts are to help with landing jolts. I added my two receivers to each side of the jet and made 4 antenna holders out of a plastic tube, fuel tubing and foam tube holder. I use this type of holder on my helis it has been a very simple effective method so I use it on everything. The only thing I need to mount is the Robbe GPS sensor, I forgot about it until today. I will use this until I can get a Igyro/gps senor down the road.
Two new videos are uploading. It may be slow going for few days till I get the items I need
ID:	2047970   Click image for larger version
ID:	2047971   Click image for larger version
ID:	2047972   Click image for larger version
ID:	2047973   Click image for larger version
ID:	2047974   Click image for larger version
ID:	2047975   Click image for larger version
ID:	2047976   Click image for larger version
ID:	2047978   Click image for larger version
ID:	2047979   Click image for larger version
ID:	2047980   Click image for larger version
ID:	2047981   Click image for larger version
ID:	2047982   Click image for larger version
ID:	2047983   Click image for larger version
ID:	2047984   Click image for larger version
ID:	2047986   Click image for larger version
ID:	2047987   Click image for larger version
ID:	2047988   Click image for larger version
ID:	2047989   Click image for larger version
ID:	2047990   Click image for larger version
Old 11-17-2014, 10:28 PM
  #44
In the Haze
I have found that there is quite a bit of play in the hinge pins, especially the ailerons and flaps. The holes in the hinge plates are a bit big for the wire hinge pin. Once you have hooked up the servos, pushrods etc. the movement in the surfaces (up and down) is pretty bad. I need to think of a way to bush the hinge where the wire pins go through to sort this out.
Old 11-20-2014, 07:05 PM
  #45
FenderBean
FenderBean's Avatar
FINALLY The servo arms arrive!!! LOL well now I can get back to some building. Its been a good day, started out rough being very tired this morning morning and riding 7.2 miles and working all day but it ended good. Got three boxes of stuff and I found out my F-14 is out of paint!!!!So the count begins.
Anyway build related my Gear fail safe/ sequencer isnt working right and will be going back to dreamworks for a checkout but while I wait on that I will be adding two small nickel size air gauges and continuing with the build. I installed the last flap servo and cut the slot for the arm and will be moving on to the elevators and rudders next.
Two cutting action videos uploading on my channel
Please not the new shop tool! Thanks Paul but my wife is taking the rest but I managed to grab a few
Okay so moving on to the elevators and I am going to trim the 2in swb arm down about 1/2 in the stabs are much thinner than the rudder and wings. I am doing this to prevent cutting a servo arm open longer than it needs to be. Plus if I cut this channel it would get in to area that I dont want to cut.
So just to clarify the aileron arms need to be at least an 1 inch, flaps 2 inch, rudder 1.5-2 inch and elevator probably could get away with 1 inch but i recommend 1.5 in nose steering was 1 inch
Wings are ready to cut and glue the control horns in but im stopping for the night, im just tired. The Army is tough on the joints after 15 years. Cheers!
ID:	2048954   Click image for larger version
ID:	2048956   Click image for larger version
ID:	2048979   Click image for larger version
ID:	2048980   Click image for larger version
ID:	2048981   Click image for larger version
ID:	2048982   Click image for larger version
ID:	2048983   Click image for larger version
ID:	2048985   Click image for larger version
Old 11-20-2014, 09:01 PM
  #46
FenderBean
FenderBean's Avatar
I also forgot to mention that all the control surfaces have a rod slid through that can be pulled out to remove the surfaces. No sure how I like this yet I guess well see over time how it holds up, mine are all tight for sure no slop so far!
Old 11-21-2014, 08:14 PM
  #47
FenderBean
FenderBean's Avatar
Slow going tonight, dad time was taking priority but I did manage to get the pivot points taped on the control surfaces. This was done by removing the surface and using the pin as a guide, after this I marked the control horn slots. Next thing is to cut the slots, align the control horn with the pivot point and hysol them in. I am uploading a video explaining the same things here, plus some off topic stuff so check out my channel for that. I found a nice little product to replace those nasty zip ties so I will be using it from now on instead. Tomorrow will be more productive I hope after this not much else to do until a turbine shows up
https://www.youtube.com/channel/UCE_...BAxA8bHVCw3VQQ
Some may be wondering what the electronics are for
ID:	2049230   Click image for larger version
ID:	2049231   Click image for larger version
ID:	2049232   Click image for larger version
ID:	2049233   Click image for larger version
ID:	2049234   Click image for larger version
ID:	2049235   Click image for larger version
ID:	2049236   Click image for larger version
ID:	2049238   Click image for larger version
ID:	2049239   Click image for larger version
Old 11-21-2014, 08:33 PM
  #48
FenderBean
FenderBean's Avatar
I just have to post a teaser.
Coming to a build near you!
Old 11-22-2014, 01:43 PM
  #49
FenderBean
FenderBean's Avatar
Okay after much effort the control horns are cut, what a pain in the butt! SM needs to do a better job about block placement for the control horns period. I do have wood to hold to in everything except the ailerons so I will add some epoxy soaked sponge to hold it. What I didnt think about and you have to be careful about is the plastic tube inside the control surface the pin is guided threw. SM put the control horn location inline with a pivot point that just bad mojo so it requires care in cutting a glue placement our you will mess something up.
Vidoe is uploading that describes this stuff, im going to get some sponge cut and epoxy mixed up. After this not much I can do but mount the tanks and wait for a turbine.
ID:	2049381   Click image for larger version
ID:	2049382   Click image for larger version
ID:	2049383   Click image for larger version
ID:	2049384   Click image for larger version
Old 11-22-2014, 06:09 PM
  #50
FenderBean
FenderBean's Avatar
Okay I have all the control horns semi glued in and im taking a break before I start throwing stuff at the walls LOL After getting the hinges in I really think the ones they supplied with the kit are to small. Longer horns are going to be a recommendation for skymaster on this kit, no way possible to get the horns down to the bottom skin like I like them to be. Beer time and some couch time with the miss!
ID:	2049470   Click image for larger version
